1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: Modbus
To: <[email protected]>
Date: Fri, 17 May 2013 14:21:11 -0700
Hi Dan,
I am not familiar with RIO.  Here at SLAC we are using Beckhoff for number of different applications.  We mostly use simple Beckhoff devices, like ADC, DAC, digital IO, which are relatively easy to deal with, in spite off that each of these modules has a number of hidden registers.  In these modules, hidden registers need to be accessed only to change some configuration parameters.  Recently, one of the experimenters added Beckhoff stepper motor controllers.  In these devices, there are hidden registers that need to be accessed frequently to monitor the position of the motor.  There are other hidden registers that also need to be accessed to set up the motor motion.  Because of all this, life became a bit more difficult.
Thanks for your reply,
Zen
On 05/17/13 13:52, DJ Roberts wrote:
Hi Zen,
This is my first post to this tech-talk. I was surprised to see that the Beckhoff hides much of its useful memory.
Have you tried a RIO? I recently used one and the whole array table is read/write via modbus and all operations are done in one modbus packet. I even wrote some embedded code to store some interesting data in the array so I could get at it via the modbus front end. Here's the one I used: http://www.galilmc.com/products/rio-47xxx.php
-Dan
-------- Original Message --------
Subject: Modbus
Date: Thu, 16 May 2013 11:38:00 -0700
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Hi Mark,
I am still working on an IOC to control stepper motors with Beckhoff
devices (KL2431 and KL2541).  I am using your modbus (R2.2) support module.
Beckhoff devices are called bus terminals.  A bus terminal has two types
of registers.
One is a small set, typically 2 and in the case of the KL25x1 terminals
3, that one can read from or write to directly.  Let's call them
visible.  The poll thread in modbus does IO to these registers.
The other type is what I call "internal" or invisible registers. One can
access these registers via the visible registers only. Hence, multiple
operations need to be performed on the visible registers to either read
from or write to an invisible register.
I find that while I am writing to one of the invisible registers, at
times the periodic reading from the visible registers in the poll
thread, interferes with the writing process.
I assume that I can control the poll timeout using your
poll_delay.template record.
So, I am thinking that I need to change the poll timeout for the
terminal I am trying to write to to "disable" poll reading from the
terminal.  I use seq records to sequence these read and write operations
and I could add at the beginning of the sequence a request to set the
timeout, to let's say 10 seconds, and at the end of the sequence restore
the original timeout.
Is the thread woken up when a new timeout value is written out to the
modbus module?
Is there a better way to make sure that the poll reads do not interfere
with the reading from and writing to the invisible registers?
Thanks Mark,
Zen
Re: Fwd: Modbus DJ Roberts
Prev: Re: AW: Modbus Zenon Szalata
Next: More on Modbus Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: Modbus DJ Roberts
Next: Modbus Zenon Szalata
