1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus
To: Mark Rivers <[email protected]>, Ernest Williams <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 5 Aug 2013 09:33:03 -0700
Hi Mark,
I am nearly done with my version of modbus TCP for use with Beckhoff hardware. I have a few IOCs using this support module and all seems to be working well in my test area. I have deployed an IOC for a couple of stepper motors controlled by Beckhoff devices in a production area and discovered that the IOC is generating many errors.
The error is:
2013/08/05 08:55:14.982 modbusAsyn::doModbusIO port BKH15 error calling writeRead, error=sioc-esb-bkh15:502 timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
Now, modbusAsyn is the name I used for the file which has the two routines I took from your file drvModbusAsyn. Looking at the log files of the IOCs used in the same production area which control Beckhoff devices and which are built with your modbus support module, I see that the same errors are generated. Here is an example:
2013/06/16 13:19:25.918 drvModbusAsyn::doModbusIO port BKH10_CPL_R0 error calling writeRead, error=sioc-esb-bkh10:502 timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
People who use these IOCs ignored these errors because mostly they did not matter.
In the case of the stepper motor controller IOC it does matter. First of all I realized that the difference between my testing environment and that of production is the computer speed and a different networking environment. The production computer used for the Beckhoff IOCs is much faster. So it seems that there is some timing issue at work here. After putting print statements in various places, I see that the routine writeIt in modbusInterpose.c file always succeeds but the routine readIt in the same file fails from time to time. I reread the manual for the Beckhoff BK9000 Ethernet coupler and came across a statement saying that the coupler takes from 13 to 15 ms to process a modbus message. So it seems that the read comes too soon after the write. In my version of the modbus support module for Beckhoff, I have added a 20 ms delay after the pasynOctet->write in modbusInterpose.c and this has mostly solved the problem. I say mostly, because I still see this error message but very infrequently. I am writing all this because I don't understand why this error is generated so I am not sure if the direction I took to fix the problem is correct. I also think that your modbus support module may need to be modified if it is to be used with Beckhoff devices.
I would like to hear what you think about this.
Zen
RE: Modbus Mark Rivers
Prev: Record Parameters in Asyn Port Driver Igor H. Soares Nunes
Next: RE: Modbus Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: Modbus Zenon Szalata
