1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gauge controller with R232 serial port
To: Mark Rivers <[email protected]>, Vahe Sahakyan <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 30 May 2013 08:34:39 -0700
On May 30, 2013, at 4:43 AM, Mark Rivers <[email protected]> wrote:
> This error:
> drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
> asynSetOption("L0", -1, "baud", "9600")
> setOption failed tcsetattr failed: Input/output error
> probably means either that /dev/ttyS0 does not exist, or you don't have permission to modify it.
I would have thought that existence or permission errors would be reported by the drvAsynSerialPortConfigure command itself rather than being reported by the asynSetOption commands.   The "Input/output" errors shown in the message kind of imply that "/dev/ttyS0" is present and accessible, but does not respond to tcsetattr commands.  Could it be that "/dev/ttyS0" doesn't actually refer to a termios serial device?   Seems awfully unlikely, but that is what the errors are reporting.
What hardware and operating system is being used?  What kind of serial port hardware?
Eric Norum
[email protected]
Gauge controller with R232 serial port Vahe Sahakyan
Re: Gauge controller with R232 serial port Ralph Lange
Re: Gauge controller with R232 serial port Eric Norum
Re: Gauge controller with R232 serial port Vahe Sahakyan
RE: Gauge controller with R232 serial port Mark Rivers
Prev: RE: PI C863's direction status can't change in time as leaving the limit switch Mark Rivers
Next: Re: EPICS on an embedded device So, Sung-Leung
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Gauge controller with R232 serial port Mark Rivers
Next: Device support for Copley Controls Accelnet Panel Phillip Sorensen
