> The second reason is that the standard EPICS errlog facility can be used to
> much the same effect (and note that it uses a much saner locking policy), i.e.
> a simple wrapper around errlogPrintf, perhaps using a CPP macro to add the
> state set and/or program name to the message.
#define PRINTF errlogPrintf
> Admittedly, you cannot log
> different program instances into different files, but if you incorporate a
> suitably unique string into the messages then filtering them out of the IOC-
> wide log file can be done easily with standard unix command line tools such as
> grep.
Are you talking about redirection like
Then the 'logfile' parameter provided to the seq is obviously ignored.
The only issue I have with this is that it is all or nothing.
Admittedly, with the SEQ I can use grep when errlogs are redirected to a file.
BUT I am not so sure I can do this with other application (stream ,etc)
But when there is no redirection, my IOC terminal is flooded with potentially irrelevant messages.
As anyone found a smart/easy way to filter/redirect messages based on the message source (asyn, stream, seq, autosave, etc) ?
