1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PV name change and autosave
To: [email protected]
Date: Fri, 07 Jun 2013 16:33:13 -0500
Here's an example from one of our beam lines
in the st.cmd file:
---------------% st.cmd %------------------------
# create the motor PVs
dbLoadTemplate("motor.substitutions")
#... later, after iocInit
# save other things every thirty seconds
create_monitor_set("auto_settings.req",30,"P=12ida2:")
-----------------------% end %------------------------
---------------% motor.substitutions %------------------------
file "$(MOTOR)/db/motor.db"
pattern
{P, N, M, DTYP, C, S, DESC, EGU, DIR, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES, PREC, DHLM, DLLM, INIT} {12ida2:,1,"m$(N)","OMS MAXv",0,0,"motor $(N)","Angle Degree",Neg, 0.25, 0, 1, 0, 0.125, 1,5E-6, 8,2.1264,-26.8796,""} {12ida2:,2,"m$(N)","OMS MAXv",0,1,"motor $(N)","Slide mm",Pos, 4, 0, 0.5, 0,0.689655, 1,0.00344827586206897, 8,352.2823,215.2823,""} {12ida2:,3,"m$(N)","OMS MAXv",0,2,"motor $(N)","mm",Pos,0.130005, 0, 0.5, 0,0.130005, 1,0.000130009932758863, 8,14854.6,14853.6,""} {12ida2:,4,"m$(N)","OMS MAXv",0,3,"motor $(N)","mm",Pos,0.0330033, 0, 0.5, 0,0.0330033, 1,3.3000033000033E-5, 8,102123.97,-87822.03,""} {12ida2:,5,"m$(N)","OMS MAXv",0,4,"motor $(N)","mm",Pos, 0.4, 0, 0.25, 0, 0.4, 0.25,0.0004, 8,532.8156,-36.2838,""} {12ida2:,6,"m$(N)","OMS MAXv",0,5,"motor $(N)","mm",Neg, 0.4, 0, 0.25, 0, 0.4, 0.25,0.0004, 8,94.793,-115.2106,""} {12ida2:,7,"m$(N)","OMS MAXv",0,6,"motor $(N)","mm",Neg, 1, 0, 0.25, 0, 0.4, 0.25,0.0004, 8,89.001,-136.5194,""} {12ida2:,8,"m$(N)","OMS MAXv",0,7,"motor $(N)","mm ",Pos, 1, 0, 0.25, 0, 0.4, 0.25,0.0004, 8,517.062,-15.19,""}
---------------% auto_settings.req %------------------------
# Note: the macro P must have been supplied to the routine that parses
# this file.  Normally, this means a command like the following is in st.cmd
# create_monitor_set("auto_settings.req",30,"P=12ida2:")
# This requires save_restore v2.8 or later.
file motor_settings.req P=$(P),M=m1
file motor_settings.req P=$(P),M=m2
file motor_settings.req P=$(P),M=m3
file motor_settings.req P=$(P),M=m4
file motor_settings.req P=$(P),M=m5
file motor_settings.req P=$(P),M=m6
file motor_settings.req P=$(P),M=m7
file motor_settings.req P=$(P),M=m8
------------% $(MOTOR)/db/motor_settings.req %--------------
# FILE... motor_settings.req
# Version:        $Revision$
# Modified By:    $Author$
# Last Modified:  $Date$
# HeadURL:        $URL$
$(P)$(M).DIR
$(P)$(M).DHLM
$(P)$(M).DLLM
$(P)$(M).TWV
$(P)$(M).SREV
$(P)$(M).MRES
$(P)$(M).ERES
$(P)$(M).RRES
$(P)$(M).VBAS
$(P)$(M).VELO
$(P)$(M).ACCL
$(P)$(M).BDST
$(P)$(M).BVEL
$(P)$(M).BACC
$(P)$(M).RDBD
$(P)$(M).DESC
$(P)$(M).EGU
$(P)$(M).RTRY
$(P)$(M).UEIP
$(P)$(M).URIP
$(P)$(M).DLY
$(P)$(M).RDBL
$(P)$(M).PREC
$(P)$(M).DISA
$(P)$(M).DISP
$(P)$(M).FOFF
$(P)$(M).OFF
$(P)$(M).FRAC
$(P)$(M).OMSL
$(P)$(M).JVEL
$(P)$(M).JAR
$(P)$(M).VMAX
$(P)$(M).PCOF
$(P)$(M).ICOF
$(P)$(M).DCOF
$(P)$(M).HVEL
$(P)$(M).NTM
$(P)$(M).NTMF
$(P)$(M).INIT
$(P)$(M).PREM
$(P)$(M).POST
$(P)$(M).FLNK
$(P)$(M)_able.VAL
hope this helps
On 6/7/2013 4:22 PM, Emmanuel Mayssat wrote:
Date: Fri, 7 Jun 2013 14:47:11 -0500
Normally, I just include a line of the form
     file <request file> <macro definitions>
for each database whose PVs I want autosaved.
I am not sure I understand.
where do you include that line?
Do you have a pointer on some docs or example?
E
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
PV name change and autosave Emmanuel Mayssat
Re: PV name change and autosave Tim Mooney
RE: PV name change and autosave Emmanuel Mayssat
Prev: RE: PV name change and autosave Emmanuel Mayssat
Next: Re: PV name change and autosave Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
