We have several instances of a sequencer that occasionally start getting messages such as this, every 10 seconds or so:
sevr=fatal pvGet(ss sscanner, var PVL[23], pv SR08U___GDS1HS_BC03): failed (timeout waiting for other get requests to finish)
examining that channel with seqChanShow shows: #84 of 99: Variable name: "PVL[23]" type = long count = 1 Value = 0 Assigned to "SR08U___GDS1HS_BC03" Connected
Not monitored Not sync'ed Status = 10 Severity = 2 Message = get completion timeout Time stamp = 2013-06-08 22:00:24.857905 Next? (+/- skip count) Looking at the code in seq_ca.c and seq_if.c, it seems that if a synchronous pvGet ever fails to get a callback from channel access, the "get completion timeout" message is set in the channel metadata and all subsequent attempts to do pvGets on that channel will fail as in the first message. The latter occurs because there is a get semaphore for each channel that the callback is supposed to give.
My thought is that if the callback doesn't come the semaphore should be released in the same code that sets the "get completion timeout" message. Or is there something the operator should be able to do, short of restarting the sequencer?
Carl
-- Carl Lionberger Controls Software Developer LBNL Engineering Division 510 486 7503
- Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
RE: StreamDevice protocol file for Televac MM200 VGC Xu, Huijuan
RE: StreamDevice protocol file for Televac MM200 VGC Mohan Ramanathan
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
