1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: LAN GPIB
To: <[email protected]>
Date: Thu, 13 Jun 2013 08:10:26 -0700
I am using both.  Both work reasonably well.  The Agilent unit is a bit more robust, since the ICS device is more likely to be adversely affected by computer security scans.  If you put the LAN-GPIB gateway on a private sub-net, then they both will do well.  The Agilent is significantly more pricey.
Zen
On 06/13/13 01:01, BOGARD Daniel wrote:
I plan to do GPIB with asyn using a LAN/GPIB  gateway and EPICS running on a Linux PC.
What is the best choice for the gateway between Agilent E5810B and ICS8065?
Thanks in advance.
Daniel Bogard
Accelerators Control engineer .
Saclay(France)
[email protected]
Re: LAN GPIB Anthony Pietryla
LAN GPIB BOGARD Daniel
Prev: Re: LAN GPIB Weiwei Lu
Next: Re: LAN GPIB Anthony Pietryla
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
