On 6/14/13 3:45 PM, Till Straumann wrote:
> My 2 cents:
> I advise against setting this (or any) property from code.
> This might surprise and/or frustrate users who *do* want
> to use property files etc.
> You can set 'jca.use_env' from a file or even on the command line
> java -Djca.use_env=true
> Cheers
> - Till
Hi, Till.
I think it depends on the situation. If you're deploying a program or
library for someone to use, I think it's fine to set the property in
code if you've decided that's how the program or library behaves--it
take CA configuration from the environment.
In Mark's example, I think it also makes sense because he's deploying a
plug-in for ImageJ. Plenty of people will start ImageJ by simply
double-clicking an application icon for it; they're not starting it by
typing "java" and arguments at a command prompt. And again, he's
effectively defining how the plug-in receives its CA configuration--from
the environment, not from a properties file. He could put the
properties file in the areaDetector plug-in JAR file, but what use is
that? No one is going to extract it, change the properties file, and
create the JAR file again. That's a pain, and now you've also modified
the JAR in a site specific way.
Where a properties file could be useful is for a library where its
environment might be harder to control (e.g. in a Servlet running in
Tomcat).
Or it could be useful just for the case you're talking about where a
user wishes to be able to control it with a properties file. But that's
up to the author of the application or library to decide how they want
to allow it to be configured.
Lewis
- CAJ/JCA question Sinisa Veseli
- RE: CAJ/JCA question Mark Rivers
- Re: CAJ/JCA question Till Straumann
RE: EPICS device disconnects and reconnects Feng, Kate
Re: analog output record - constant DOL Rolf Keitel
<2013>
2025
EPICS device disconnects and reconnects Mark Rivers
<2013>
2025
