1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AutoSAVE file cannot use substitution macros
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Thu, 20 Jun 2013 17:19:03 +0200
Hi Tim
I think I'll stick to my old method for now.
I'm off for the week but thanks to you and Mark.
I think we can close this query.
Thanks
Amien
On 20-Jun-2013 16:36, Tim Mooney wrote:
Hi Amien,
When you use create_monitor_set(), autosave normally won't write a .sav file unless a
PV in the set has changed.
In autosave 5.1 is a new facility called configMenu, which does permit the loading of
a .cfg file (same as a .sav file, but with a different extension) with macros, as long
as all the macros were previously defined in a create_xxx_set() call, as they are in
your case.  I'm not sure configMenu is the best thing for your application.  It's intended
to let users select one of several .cfg files for loading at run time.
Tim
----- Original Message -----
To: "Mark Rivers" <[email protected]>
Sent: Thursday, June 20, 2013 9:14:17 AM
Hi Mark
here's my test.req
$(P):channelmap .VAL @array@ { "32" "0" "1" "2" "3" "4" "5" "6" "7"
"24" "25" "26" "27" "28" "29" "30" "31" "47" "17" "18" "19" "20"
"21" "22" "23" "8" "16" "10" "11" "12" "13" "14" "15" "9" "33" "34"
"35" "36" "37" "38" "39" "40" "41" "42" "43" "44" "45" "46" }
my auto_settings.req
file "test.req", P=$(dev)
and in my st.cmd
##################### START IOC SCRIPT
dbLoadDatabase("iocBeagle48.dbd")
iocBeagle48_registerRecordDeviceDriver(pdbbase)
int32DriverInit("int32",-32768,32767)
##epicsEnvSet("PREFIX", "13SIM1:")
##### We load the HARPS template
dbLoadTemplate("iocPV.substitutions")
##### Load Save files
set_savefile_path("save")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
##### INIT IOC here
iocInit()
create_monitor_set("auto_settings.req",30,"P=$(harp100)")
Under my /save directory I have auto_settings.sav
I do not see anything in here after 30 seconds intervals...??
What I'm I doing wrong?
Amien
On 20-Jun-2013 15:40, Mark Rivers wrote:
You did not show us the autoSave .req file you are using.  .req
files
can take macros.  For example:
corvette:areaDetector/ADApp/Db>more ADBase_settings.req
$(P)$(R)DataType
$(P)$(R)ColorMode
$(P)$(R)BinX
$(P)$(R)BinY
$(P)$(R)MinX
That generic .req file is invoked by the IOC-specific .req file:
corvette:areaDetector/iocBoot/iocSimDetector>more auto_settings.req
file "simDetector_settings.req",    P=$(P),  R=cam1:
file "simDetector_settings.req",    P=$(P),  R=cam2:
file "ADBase_settings.req",         P=$(P),  R=cam1:
which is in turn invoked from the startup script:
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=$(PREFIX)")
on behalf of Amien TLABS [ [email protected] ]
Sent: Thursday, June 20, 2013 8:23 AM
To: [email protected] Subject: AutoSAVE file cannot use
substitution macros
Hi
I'm using a 'waveform' record in my IOC, which I use to map my
cable
wiring to my channels at the start of the IOC.
To populate the array, I then use a 'sav' (AutoSave) file that has
the array values in it ( dev1:channelmap.VAL @array@ {"2" "12"
"7"})
) etc. This array is normally 48 elements.
Now the users of the IOC can change this array to suit their
mappings.
My problem is that I would like to have a substitution macro in the
'dev1' part. However, one cannot use a substitution macro in a
'sav'
file.
I have a waveform record in my template file. Here's my st.cmd and
template files:
set_pass0_restoreFile("channelmap_MB.sav")
set_pass1_restoreFile("channelmap_MB.sav")
#### INIT IOC here
iocInit()
<<< Here's my iocPV.db >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
record(waveform,   "$(dev):channelmap") {
field(DTYP, "asynInt32ArrayOut")
field(INP,  "@asyn(int32 0 100)")
field(NELM, "48")
field(FTVL, "LONG")
field(PINI, "YES")
<<< here's my substitution file >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
file iocPV.db
pattern { dev        mux }
{"harp100"   "1" }
<<<<<<< and my SAV file  >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
# save/restore V5.5    Automatically generated - DO NOT MODIFY -
130215-051243
harp100:channelmap.VAL @array@ { "32" "0" "1" "2" "3" "4" "5" "6"
"7"
<END>
As you can see, i want to have a substitution macro for my sav file
(harp100 should be substituted by pattern dev)
Or maybe there is a better way to populate my waveform.
Thanks
Amien
TLABS
Cape Town.
Re: AutoSAVE file cannot use substitution macros Tim Mooney
Prev: Re: Edm Histogram Southern, Tim
Next: starting Archive Engines James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AutoSAVE file cannot use substitution macros Tim Mooney
