Hello all, I've managed to start an RDB archive engine using an xml file from the old channel archiver setup at STAR. However, I feel like I'm doing something wrong. The engine runs on the command line and none of the channels are connected, though I can see it at localhost:4913/main. Here is how I start it: ./ArchiveEngine -engine CANbusRDB -port 4913 The SNS site documentation has -rdb_url, -rdb_user, and -rdb_password listed as options that should be used, but none of those are listed when I do ArchiveEngine -help and they throw an error when I use them to run the engine. I think they are built in to the plugin_customization.ini file for org.csstudio.archiver.engine, but they may still be needed on the command line. Another bit of information is that I can't see this engine or RDB when I do a "show engines" or "show databases" from the archive user on mysql. Perhaps I'm missing something that makes it run on mysql. Thanks James
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
