1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: help setting up XY table control with EPICS StreamerClass
To: Christian Pauly <[email protected]>
Date: Fri, 21 Jun 2013 09:31:57 -0400
Hi Christian,
Is there a reason this is implemented using basic records and streamDevice, and not using the motor record and an Asyn motor driver? If you had an Asyn motor driver, you would be able to use the motor record, which has fields such as DMOV (done moving), MOVN (currently moving), etc…
It also supports ca_put_callback for you, so you can write a new position and wait for move completion before the function/database put returns.
However, perhaps the controller is so simple it wasn't worth doing a motor driver for it? But even with simple controllers I have found that it's often worth developing an Asyn motor driver for it just to take advantage of all the features that the motor record provides. Not to mention the fact that you maintain a consistent interface for all motors.
Cheers,
Matt
On Jun 21, 2013, at 5:52 AM, Christian Pauly <[email protected]> wrote:
> Ok, i see.
> But still:
> How can i get then information if the motors are running at the moment,
> or not. Without doing periodic scans on the PACT fields ??
> On 06/21/2013 11:39 AM, Ralph Lange wrote:
>> Hi Christian,
>> On Fri Jun 21 2013 11:07:38 GMT+0200 (CEST), Christian Pauly
>>> No, only one motor can move at a time.
>>> But i thought it is "bad style" to do this synchronous with such large
>>> delays ? ( I had to define huge timeouts in the protocol to get it
>>> work...)
>> This rule of not doing synchronous device support for devices with long
>> delays applies to writing device support.
>> If you are using StreamDevice (which I assume), your device support is
>> not synchronous - StreamDevice and ASYN support below are working
>> asynchronously and take care of the gory details for you.
>> The port that you are communicating with will be locked while a protocol
>> (like your move command) is running. But that is fine if the device can
>> only use one motor at a time.
>> Cheers,
>> ~Ralph
> Dr. Christian Pauly
> Bergische Universität Wuppertal
> Fachbereich C - Physik
> Gaußstraße 20, D-42119 Wuppertal
> Tel: +49 (0)202 439-2632,
> Fax: +49 (0)202 439-2662
Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
Re: help setting up XY table control with EPICS StreamerClass Ralph Lange
Prev: Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
Next: RE: Using all the cores available on modern processors nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: help setting up XY table control with EPICS StreamerClass Tim Mooney
