Hi Benjamin,
> your proposal tries to reify all the possible ways to compare two closures
> (listener code + environment) as data. Another approach, which I personally
> prefer, is to let users define their own matching criteria, i.e.
This is a C API, C doesn't have closures, and we're talking about changing a
minor part of a minor EPICS API. We don't have anything comparable to your
matcher routine in the rest of Base and it would be confusing to introduce
this kind of thing here. I only included all the possibilities I did because
there are valid use-cases to need both flag bits. I don't want to change the
listener API like your proposal does; there is no reason to break user code
unnecessarily, and my version is completely backwards-compatible for existing
errlog listener source code.
> IMO, removing only the first matching list element is unsafe and should
> not be supported.
That behavior is explicitly tested for and relied on in the epicsErrlogTest.c
code. The errlogRemoveListener() routine has behaved like that for a long
time and might actually be relied on in the wild for all we know...
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Problem in errlogRemoveListener Michael Abbott
- Re: Problem in errlogRemoveListener Andrew Johnson
- Re: Problem in errlogRemoveListener Benjamin Franksen
PyEpics speed Jeremy Iken
<2013>
2025
<2013>
2025
