1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in errlogRemoveListener
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 28 Jun 2013 13:50:08 -0500
Hi Lewis,
On 2013-06-28 J. Lewis Muir wrote:
> I don't get why one would care about removing all listeners that match.
> I can't think of a scenario where it would make sense to add more than
> one listener/pvt pair.  To me, if someone does that, it's a bug.  I'd be
> fine with the name still singular and it removing the first matching
> listener/pvt pair:
It may be a bug to do that, but all it takes is a subsystem that doesn't have
its own "already initialized" variable being started up twice.  By deleting
all matching listeners and returning how many there were I'm making the
resulting code more robust against that kind of error while also allowing the
problem to be detected by the caller if s/he so desires.  If you want to be
able to delete your listeners separately, pass a different value for the
private argument for each one.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Problem in errlogRemoveListener Andrew Johnson
Re: Problem in errlogRemoveListener J. Lewis Muir
Prev: Re: Problem in errlogRemoveListener J. Lewis Muir
Next: Re: Problem in errlogRemoveListener Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
