1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in errlogRemoveListener
To: <[email protected]>
Date: Fri, 28 Jun 2013 21:38:26 +0200
On Friday, June 28, 2013 12:32:53 Andrew Johnson wrote:
> On 2013-06-24 Benjamin Franksen wrote:
> > I challenge you to come up with a real
> > world example that needs anything besides my originally proposed
> >         void errlogRemoveListener(listener *, void *);
> > which should remove all listeners with matching function pointer and
> > private data pointer.
> I accept your argument, thanks.  Here's what I'll change it to for the next
> 3.15 release:
>     int errlogRemoveListeners(errlogListener listener, void *pvt);
> The return value is the number of listeners that were actually removed.
Thanks, I am completely happy with that.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachm€nts
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Problem in errlogRemoveListener Andrew Johnson
Re: Problem in errlogRemoveListener Benjamin Franksen
Prev: Re: Problem in errlogRemoveListener Andrew Johnson
Next: registerRecordDevice... crashes IOC during startup Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Multiple PCI-PCI Bridges Ned Arnold
