1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Multiple PCI-PCI Bridges
To: Tech Talk <[email protected]>
Date: Fri, 21 Jun 2013 11:27:28 -0500 (CDT)
Hello world -
I was wondering if anyone has experience with configuring PCI-PCI bridges for optimum performance (pre-fetching, wait states, etc)?  I have an MVME6100 (running vxWorks 5.5.2) with a PMC carrier board (specifically an Emerson/Motorola PMCspan) and a very old VMIC reflective memory PMC board.  This configuration has two PCI-PCI bridges between the CPU and the actual PMC board.  I am getting *extremely slow* data transfers between the processor and PMC card (reading 320 floats takes 460 microseconds!) .
So far I have tried ... with zero success ...
  - enabling "Fast back-to-back transfers"
  - ensuring the Pre-fetch memory range on both bridges encompasses the PMC board's address
Appended below is the output of pciConfigTopoShow, the PMC card is device [2,2,0].
Any help/hints/references would be appreciated ...
   Ned
iocrtfbdaq> pciConfigTopoShow
[0,0,0] type=MEM_CNTLR
        status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV )
        command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE )
        bar0 in prefetchable 32-bit mem space @ 0x00000000
        bar2 in prefetchable 32-bit mem space @ 0x40000000
        bar4 in prefetchable 32-bit mem space @ 0xe0800000
[0,0,1] type=MEM_CNTLR
[0,0,2] type=MEM_CNTLR
[0,0,3] type=MEM_CNTLR
        bar0 in 64-bit mem space @ 0xff000000
[0,0,4] type=MEM_CNTLR
        bar4 in I/O space @ 0x00000000
        bar5 in I/O space @ 0x00000000
[0,0,5] type=MEM_CNTLR
        status=0x0000 ( DEVSEL=0 )
        command=0x0000 ( )
[0,0,6] type=MEM_CNTLR
        command=0x0000 ( )
[0,0,7] type=MEM_CNTLR
        command=0x0000 ( )
[0,5,0] type=UNKNOWN (0x80) BRIDGE
        status=0x0230 ( CAP 66MHZ DEVSEL=1 )
        command=0x0006 ( MEM_ENABLE MASTER_ENABLE )
        bar0 in 64-bit mem space @ 0xe0000000
[0,6,0] type=P2P BRIDGE to [1,0,0]
        base/limit:
          mem=   0xe0100000/0iocrtfbdaq> pciConfigTopoShow
        command=0x0000 ( )
        command=0x0000 ( )
        command=0x0000 ( )
        base/limit:
          mem=   0xe0100000/0xe01fffff
          preMem=0x00000000e0100000/0x00000000e01fffff
          I/O=   0xe0900000/0xe00fffff
        status=0x02b0 ( CAP 66MHZ FBTB DEVSEL=1 )
        command=0x0007 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE )
[1,4,0] type=P2P BRIDGE to [2,0,0]
        base/limit:
        status=0x0290 ( CAP FBTB DEVSEL=1 )
        command=0x0207 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE FBTB_ENABLE )
[2,2,0] type=NET_CNTLR
        command=0x0082 ( MEM_ENABLE WC_ENABLE )
        bar0 in 32-bit mem space @ 0xe0100000
xe01fffff
        base/limit:
Prev: RE: Looking for an network scope (with epics driver!) Emmanuel Mayssat
Next: RE: help setting up XY table control with EPICS StreamerClass Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in errlogRemoveListener Benjamin Franksen
Next: feller release 0.4 Benjamin Franksen
