> I am not an expert of the internals of asyn. What does
> "synchronousLock:Yes" mean?
The "synchronousLock" is a per-port epicsMutex. synchchronousLock:Yes means that the mutex is currently being held by some thread. The synchronousLock is used to protect code in several places, including when a synchronous driver (i.e. one created without the ASYN_CANBLOCK attribute) calls the client callback. It is also the mutex that is used by pasynManager-lockPort().
There is one other per-port mutex used by asyn which is called asynManagerLock. I have looked at the asyn code carefully and I believe that asynManagerLock and synchronousLock are always locked/unlocked properly.
Brian, can you please send your StreamDevice protocol file? Also, are you using the standard asyn IP driver, or are you using some other asyn port driver?
Sent: Wednesday, July 03, 2013 6:49 AM
To: Mark Rivers
Cc: Brian McAllister; [email protected]
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
On 02.07.2013 20:27, Mark Rivers wrote:
> When it is hung please do
> epicsMutexShowAll 1
> I think you have probably run into a deadlock, which can happen when multiple mutexes are taken/released in the wrong order.
> If you simplfy your problem to a single record does the problem go away?
> I am not an expert on using I/O Intr scanned records with StreamDevice, particularly multiple records on the same port. Dirk may be able to help with this.
> Mark
Dirk
> From: [email protected] [[email protected]] on behalf of Brian McAllister [[email protected]]
> Sent: Tuesday, July 02, 2013 1:23 PM
> To: Mark Rivers
> Cc: [email protected]
> What does it mean if synchronousLock is permanently "Yes" ?
> I see it's a mutex and that it's used in many places. Is there any way to
> find out where it is being locked/not unlocked ?
> - brian
- RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
- Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
- Re: asyn+streamDevice hangs with synchronousLock:Yes Dirk Zimoch
RE: weird error Hill, Jeff
<2013>
<2013>
