1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
Date: Wed, 03 Jul 2013 16:36:17 -0400
>>> On 7/3/2013 at 17:37:42 -0000, Mark Rivers wrote:
  > Brian, can you please send your StreamDevice protocol file?
# stream protocol file for Omega HX86PA
getRH {
  in "%RH=%f,AT\0370C=%*f,psia=%*f";
getAT {
  in "%RH=%*f,AT\0370C=%f,psia=%*f";
getP {
  in "%RH=%*f,AT\0370C=%*f,psia=%f";
The device sends data in this format:
\n\r%RH=100.00,AT\0370C=22.66,psia=14.66
  > Also, are you using the standard asyn IP driver, or are you using some
  > other asyn port driver?
drvAsynIPPortConfigure("HX86PA","172.18.0.13:2000 TCP",0,0,1)
- brian
RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Prev: RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Next: Apologies for mailman issue Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
