1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: catching python exception in pcaspy
To: Tech Talk <[email protected]>
Date: Sun, 07 Jul 2013 12:42:14 -0700
Hi, folks.  I'm wondering if it's possible to catch python exceptions in
the pcaspy Driver class.  For instance, I have a very simple dummy
server (attached), in whose write() method there is a call that should
throw a NameError.  However, when the server is running, a CA write
(e.g. "caput MTEST:RAND 3") produces the following output:
filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=479
Internal failure - unexpected problem with client's input - forcing disconnect
The server process also continues to run.
Is there a way to get a proper python exception out of this situation?
I would prefer the server to terminate with the exception, but I would
be ok with the server continuing to run if the exception in the Driver
could at least be reported to stderr or the like.  As is it's a little
tricky to debug these errors.
Thanks in advance for any help.
jamie.
#!/usr/bin/env python
From pcaspy import Driver, SimpleServer
prefix = 'MTEST:'
pvdb = {
    'RAND' : {
        'prec' : 3,
class myDriver(Driver):
    def  __init__(self):
        super(myDriver, self).__init__()
    def write(self, channel, value):
        foo
if __name__ == '__main__':
    server = SimpleServer()
    server.createPV(prefix, pvdb)
    driver = myDriver()
    while True:
        server.process(0.1)
Attachment: pgpvGv0QOXWOK.pgp
Description: PGP signature
Re: catching python exception in pcaspy Xiaoqiang Wang
Prev: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Next: Re: catching python exception in pcaspy Xiaoqiang Wang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Development with EPICS and CSS marcus . michalsky
