Subject: |
Re: multiple servers on the same (loopback) interface |
Jameson Graef Rollins <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 09 Jul 2013 18:06:41 -0700 |
On Tue, Jul 09 2013, Jameson Graef Rollins <[email protected]> wrote:
> Hey, folks. I'm trying to run multiple IOCs on the same host and
> network interface and I'm looking for tips to help get it working
> cleanly. I'm aware of some of the issues of servers sharing the same
> interface [0]. However, I assume there must be a way to support this
> situation, since I imagine it must be common. But I'm having a lot of
> trouble getting it to work.
Someone offline has pointed me to an undocumented solution that seems to
work fine, and I wanted to share it here for others that may be
interested.
Apparently addresses specified in EPICS_CA_ADDR_LIST can include
colon-separated port specifiers, i.e. N.N.N.N:PORT. This means one can
instantiate the servers on different ports:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58900 ./test/testioc.py TEST0:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58901 ./test/testioc.py TEST1:
and specify both to the client:
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST0:FOO
0
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST1:FOO
0
0$
The client therefore doesn't need to know which channels are at which
port. This also works for localhost, so dummy network interfaces aren't
required. This is a nice simple solution to the problem.
Unfortunately, it appears that this behavior (that ports can be
specified in the CA_ADDR_LIST list) is undocumented. At least I can't
find reference to it in any of the CA documentation that I've found so
far. If anyone sees a problem with this method please let me know.
Thanks so much for everyone's suggestions.
jamie.
pgpeTBsndsuhs.pgp
Description: PGP signature
- RE: multiple servers on the same (loopback) interface Hu, Yong
- multiple servers on the same (loopback) interface Jameson Graef Rollins
Re: registerRecordDevice... crashes IOC during startup Bruce Hill
Another strange CA observation Benjamin Franksen
<2013>
2025
RE: multiple servers on the same (loopback) interface Hill, Jeff
<2013>
2025
