I understand that another solution is to run the IOC in a virtualized guest OS.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Kasemir, Kay
> Sent: Tuesday, July 09, 2013 12:06 PM
> To: [email protected]
> Subject: Re: multiple servers on the same (loopback) interface
> Hi:
> The first IOC will serve on TCP port 5065.
> The second one can't do that, so you get the warning Configured TCP port
> was unavailable, ...Using dynamically assigned TCP port 34497.
> Both will try to listen to UDP search requests on the same port, then reply
> with the TCP port that they actually use, so all should be fine.
> BUT: Because of a quirk in most network kernels only one of them will
> actually see those UDP search requests. For me it's usually the IOC started
> _last_.
> If you want your clients to send search requests to all IOCs that are listening
> on the UDP port, you need to send a broadcast. Search requests sent to a
> specific IP address will only reach one of the IOCs listening on that IP.
> You can try setting the EPICS_CA_ADDR_LIST=255.255.255.255.
> With localhost, that may not be possible, so you'll have to setup some
> network interface, maybe leave it disconnected, but it must have an IP
> address and most important a broadcast address.
> -Kay
> On Jul 9, 2013, at 1:50 PM, Jameson Graef Rollins <[email protected]>
> wrote:
> > Hey, folks. I'm trying to run multiple IOCs on the same host and
> > network interface and I'm looking for tips to help get it working
> > cleanly. I'm aware of some of the issues of servers sharing the same
> > interface [0]. However, I assume there must be a way to support this
> > situation, since I imagine it must be common. But I'm having a lot of
> > trouble getting it to work.
> > Some details that may or may not be relevant:
> > * I'm using the pcaspy python bindings.
> > * I'm trying to bind all of my servers to the loopback interface (I'm
> > trying to put together a test infrastructure and this is required
> > (afaik) for offline tests).
> > I can start the first IOC no problem:
> > 0$ EPICS_CAS_INTF_ADDR_LIST=localhost ./testioc.py TEST0:
> > prefix: TEST0:
> > db: {'FOO': {'prec': 0}}
> > Client channel access works as expected:
> > 0$ EPICS_CA_ADDR_LIST=localhost EPICS_CA_AUTO_ADDR_LIST=NO caget -
> t TEST0:FOO
> > 0
> > 0$
> > When I start the second server I get the (expected) shared UDP warnings:
> > 0$ EPICS_CAS_INTF_ADDR_LIST=localhost ./testioc.py TEST1:
> > cas warning: Configured TCP port was unavailable.
> > cas warning: Using dynamically assigned TCP port 34497,
> > cas warning: but now two or more servers share the same UDP port.
> > cas warning: Depending on your IP kernel this server may not be
> > cas warning: reachable with UDP unicast (a host's IP in
> EPICS_CA_ADDR_LIST)
> > prefix: TEST1:
> > But unfortunately the first server is now no longer accessible:
> t TEST1:FOO
> > 0
> t TEST0:FOO
> > Channel connect timed out: 'TEST0:FOO' not found.
> > 1$
> > I've tried variously killing the caRepeater and accessing things in
> > different order, but nothing seems to work. Things do work if I specify
> > different EPICS_CA_SERVER_PORT for the two servers, but that's an
> > inconvenience for the client since it has to know which record is being
> > served on which port.
> > Does anyone have any suggestions on how to make this situation work?
> > jamie.
> > [0] http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html#Unicast
- multiple servers on the same (loopback) interface Jameson Graef Rollins
- Re: multiple servers on the same (loopback) interface Kasemir, Kay
RE: multiple servers on the same (loopback) interface Jameson Graef Rollins
RE: weird build Andrew C. Starritt
<2013>
2025
Re: multiple servers on the same (loopback) interface D Peter Siddons
Re: multiple servers on the same (loopback) interface Jameson Graef Rollins
<2013>
2025
