1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: weird build
Date: Thu, 11 Jul 2013 13:26:59 +1000
Hi Andrew,
  Thanks for the info.  No this won't be a issue for me - it was more a curiosity that I stumbled across.
Regards
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Sunday, 7 July 2013 3:31 AM
> To: Andrew C. Starritt
> Cc: tech-talk
> Subject: Re:
> Hi Andrew,
> This is not an intentional feature, but according to Janet Anderson it
> is a side-effect of our inclusion of .. in the list of paths that we're
> configuring vpath for the .db target. Apparently the vpath gets applied
> to targets as well as sources by GNUMake, and it causes this to happen
> because we use vpath to avoid having to duplicate some of the build
> rules.
> I have asked Janet to look at how many rules would need to be added to
> remove .. from the vpath list and we'll probably make that change on
> the 3.15 branch, but I think it's probably too big a change to do in
> 3.14.
> Thanks for the report, is this going to be a significant issue for you
> at all?
> - Andrew
> Sent from my iPad
> On Jul 4, 2013, at 8:52 PM, "Andrew C. Starritt"
> <[email protected]> wrote:
> > Hi all,
> > I found some strange build behaviour (on both base-3.14.12.3 using 64
> bit CentOs 5.9
> > and base-3.14.9 using 32 bit CentOs 5.4). If there is a db directory
> in top's parent
> > directory that contains a file with the same name as I'm trying to
> install into
> > the top's db directory, then the install does not happen.
> > The following demonstrates this:
> > cd /tmp
> > mkdir -p above_top/top
> > cd above_top/top
> > makeBaseApp.pl -t ioc Weird
> > cd WeirdApp/Db/
> > vi Makefile            # uncomment the DB += xxx.db line
> > touch xxx.db
> > cd ../..               # back to top
> > make
> > ls -l db               # the xxx.db file installed as expected - so
> far so good.
> > make clean uninstall
> > # and the weirdness starts here:
> > mkdir ../db
> > touch ../db/xxx.db
> > make
> > ls -l                  # no db diretory in top, and no installed
> xxx.db file.
> > Is this an intended feature, and if so what is the rationale?
> > Regards
> Synchrotron
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
[no subject] Andrew C. Starritt
Re: Andrew Johnson
Prev: RE: multiple servers on the same (loopback) interface Hill, Jeff
Next: StreamDevice send/recevie bit array problem zhangning
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Andrew Johnson
Next: Which version of Eclipse is required for CSS 3.2.x Xinyu.Wu
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
