1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mbbxDirect SHFT field
To: Florian Feldbauer <[email protected]>
Date: Wed, 17 Jul 2013 12:15:51 +0000
In this case since your driver knows what bits should not be modified it may be clearer to just use mask=0xffff so SHFT=0.  Then the B0, B1, etc. in the mbboDirect record map directly to the bits in the register.  Your driver just needs to not actually modify the reserved bits.
Sent: Wednesday, July 17, 2013 2:23 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Subject: Re: mbbxDirect SHFT field
Hi Mark,
thanks for your answer.
I was using this mask, because all 0-bits are marked as "reserved" in
the manual of our
motor driver. So I wanted to make sure they are not written...
Good to know how the shift is calculated...I should check my other
mbbo/mbbi records as well.
   Florian
On 07/16/2013 06:16 PM, Mark Rivers wrote:
> Hi Florian,
> If you look at the asyn/devEpics/devAsynUInt32Sigital.c device support you will see that for mbbi, mbbo, mbbiDirect and mbboDirect records the SHFT field is computed by the computeShift function in the record initialization function.
> This is the computeShift function:
> static int computeShift(epicsUInt32 mask)
>      epicsUInt32 bit=1;
>      int i;
>      for(i=0; i<32; i++, bit <<= 1 ) {
>          if(mask&bit) break;
>      return i;
> So it sets SHFT to the first non-zero bit in the mask.
> You have set the mask to 0x1f3c, which is 0001 1111 0011 1100 in binary.  The first non-zero bit is bit 2 (starting from 0) so SHFT is set to 2.
> So I think you need to use B0 and B1 for your switches, because the mask says that the mbboDirect value starts at bit 2, not bit 0 in the hardware register.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Florian Feldbauer
> Sent: Tuesday, July 16, 2013 10:15 AM
> To: EPICS Tech Talk
> Subject: mbbxDirect SHFT field
> Hey all,
> for the settings of the stop switch mode of a motor driver, we are
> using, a 16 bit code is used.
> Bit 2 and Bit 3 are coding the polarity of the "left" and "right" stop
> switch, respectively.
> I'm currently using bo records for each bit and one mbboDirect record to
> send all 16 bits at once to the device. As device support the
> asynUInt32Digital interface is used with a custom asynPortDriver:
> record( mbboDirect, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE" ) {
>     field( DTYP, "asynUInt32Digital" )
>     field( OUT,  "@asynMask($(BUS),14,0x1f3c,1)TMCM142_SAP_U" )
> record( bo, "PANDA:$(subsys):MOTOR:$(sector):SAP:LEFTSWITCHPOLARITY" ) {
>     field( OUT,  "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.B2 NPP" )
>     field( ONAM, "active high" )
>     field( ZNAM, "active low" )
> record( bo, "PANDA:$(subsys):MOTOR:$(sector):SAP:RIGHTSWITCHPOLARITY" ) {
>     field( OUT,  "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.B3 NPP" )
> When I now set "PANDA:$(subsys):MOTOR:$(sector):SAP:RIGHTSWITCHPOLARITY"
> to one,
> PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.VAL is 8.
> So far so good.
> But the value in asynPortDriver::writeUInt32Digital is 0x20.
> Having a closer look to the mbboDirect record shows that SHFT is 2.
> Setting it to 0 inside the db-file has no effect.
> Any idea why it is set to 2? How can I change this behavior?
> The same problem occurs for the mbbiDirect record used to read back the
> settings.
> Best regards,
> Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 45         |
| D-55128 Mainz                        |
| Office: 01/102                       |
| Phone:  (+49)6131 / 39-27373         |
mbbxDirect SHFT field Florian Feldbauer
RE: mbbxDirect SHFT field Mark Rivers
Re: mbbxDirect SHFT field Florian Feldbauer
Prev: Re: EPICS fsmRecord question Jiro Fujita
Next: RE: Canberra AIM MCA 556B Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mbbxDirect SHFT field Florian Feldbauer
Next: Job Opening: Control System Software Engineer Position at SNS/ORNL Kasemir, Kay
