1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: catching python exception in pcaspy
To: Jameson Graef Rollins <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Mon, 29 Jul 2013 23:47:36 +0200
Hi Jamie,
Forgive my ignorance. After examine the wrapper code created by SWIG as well as the SwigDoc,
The exceptions originated from Python could be output to stderr.
I have committed the changes to the repository. Please check it out.
Best
Xiaoqiang
On Jul 29, 2013, at 12:26 AM, Jameson Graef Rollins <[email protected]> wrote:
> On Sun, Jul 07 2013, Xiaoqiang Wang <[email protected]> wrote:
>> I have the same headache when debugging pcas applications.  The server
>> tool library does not provides an exception handler, like in the CA
>> client library, this error could only be checked from the
>> console. Even though, the error seems ambiguous and can not be
>> directly related to the python code.
>> So I normally separate functions into its own module/class/function
>> and test them.  And then interface to it by subclassing pcaspy Driver.
> Hi, Xiaoqiang.  This method seems less than ideal, since without
> subclassing the pcaspy.Driver to begin with a lot of the important
> functionality is not testable.  For instance, db read/writes are not
> possible, which is an important aspect of what the driver does.
> I don't yet understand how the server itself works, or how pcaspy wraps
> it, but I'm perplexed as to how the python exception is suppressed.  Is
> there no way we could at least coax the server into display the python
> exception error message to the console?
> In lieu of that, would it be possible to put together some sort of dummy
> server that would maybe not have all the functionality of the main
> server, but would expose the python exceptions for testing?
> jamie.
Re: catching python exception in pcaspy Jameson Graef Rollins
Re: catching python exception in pcaspy Xiaoqiang Wang
Prev: US ITER looking for CODAC/EPICS software engineering service provider DeVan, Bill
Next: RE: Electronic Logbooks Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: catching python exception in pcaspy Jameson Graef Rollins
Next: Re: catching python exception in pcaspy Jameson Graef Rollins
