I am trying to set up a Canberra DSA-2000 with EPICS + mca on a linux, x86, 64bits.
EPICS R3.14.12.3
mca R7-4
asyn 4-21
Basic operation is fine, setting up the MCA, acquiring spectra.
I am struggling with access to the integrated HV power supply, and am not sure if this is already supported by mca, so far I can't make it work.
My startup script looks like this:
AIMConfig("AIM1/1", 0x..., 1, 2048, 1, 1, "eth0")
dbLoadRecords("../../mcaApp/Db/mca.db", "P=mcaTest:,M=aim_adc1,DTYP=asynMCA,INP=@asyn(AIM1/1 0),NCHAN=2048")
icbConfig("icbHvps1", 0x..., 0, 2)
dbLoadRecords("../../mcaApp/Db/icb_hvps.db", "P=mcaTest:,HVPS=hvps1,PORT=icbHvps1,LIMIT=1300")
Not sure if the last two lines are correct.
icbShowModules says
NI...:0 9 D#QN 2993780
and
mcaAIMShowModules gives
Module Type HW rev. FW rev. Owner name Owner ID Status Memory size Free address
NI0... 1 2 7 me ..:..:..:..:..:.. Reachable 262140 00002000
Errors produced are:
2013/08/08 00:59:50.076 mcaTest:hvps1VOLT_LIM devAsynFloat64 pPvt->result.status=-1, process error
2013/08/08 00:59:50.076 mcaTest:hvps1VOLT_OUT devAsynFloat64 pPvt->result.status=-1, process error
2013/08/08 00:59:50.076 mcaTest:hvps1FRAMP devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1INH_LEVEL devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1LATCH_INH devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1LATCH_OVL devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1RESET devAsynInt32 process error
and then periodically
2013/08/08 00:59:59.576 mcaTest:hvps1INHIBIT devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1OVERLOAD devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1STATRBV devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1BUSY devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1VOLTRBV devAsynFloat64 process read error
Thanks in advance,
Fabian
- RE: mca Canberra DSA-2000 HV support Mark Rivers
Re: Modbus Zenon Szalata
Re: Wireshark CA plugin Noboru Yamamoto
<2013>
Re: Wireshark CA plugin Eric Williams
<2013>
