1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record: continuously update limit switches
Date: Fri, 9 Aug 2013 14:36:31 +0000
Hi Ron,
> Looking at the differences between the github and SVN versions of
> the  motor module, I see lots of lines with,
> <       send_mess(card, buff, (char) NULL);
> > send_mess(card, buff, (char *) NULL);
> We are not getting warnings on these lines and we should. What
> platform and compiler are you using where you see these warnings?
Probably I'm using a more recent compiler: gcc 4.7.3 as well as clang
3.2, both on Ubuntu 13.04.
By the way: There are some more warnings  (see attachment). For some of
them I don't feel comfortable in fixing them since my understanding of
the motor record code is still limited.
Martin
make -C ./configure install
make[1]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../.. T_A=linux-x86_64-debug install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure/O.linux-x86_64-debug'
perl /usr/lib/epics/bin/linux-x86_64-debug/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure/O.linux-x86_64-debug'
make[1]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/configure'
make -C ./motorApp install
make[1]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp'
make -C ./MotorSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../../.. T_A=linux-x86_64-debug install
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/motorSupport.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/motorRecord.dbd
echo "../O.Common/motorRecord.h : ../Makefile" >> motorRecord.h.d
/usr/lib/epics/bin/linux-x86_64-debug/dbToRecordtypeH  -I. -I.. -I../O.Common -I../../../dbd -I/usr/lib/epics/dbd -I/usr/lib/epics/dbd ../motorRecord.dbd motorRecord.h
Installing generic include file ../../../include/motor.h
mkdir ../../../include
Installing generic include file ../../../include/motordevCom.h
Installing generic include file ../../../include/motordrvCom.h
Installing generic include file ../../../include/motordrvComCode.h
Installing generic include file ../../../include/motor_interface.h
Installing generic include file ../../../include/paramLib.h
Installing generic include file ../../../include/asynMotorController.h
Installing generic include file ../../../include/asynMotorAxis.h
Installing generated generic include file ../../../include/motorRecord.h
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motorRecord.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motordevCom.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motordrvCom.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motorUtil.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motorUtilAux.cc
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMotorAsyn.c
../drvMotorAsyn.c:470:50: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
        (*pPvt->drvset->getInteger)(pAxis->axis, command, value);
../drvMotorAsyn.c:459:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
        case -1:   /* This is commands we know about but don't want int32 interface for */
../drvMotorAsyn.c:508:54: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
            (*pPvt->drvset->getInteger)(pAxis->axis, command, (epicsInt32*)value);
../drvMotorAsyn.c:502:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
        case -1:   /* This is commands we know about but don't want uint32digital interface for */
../drvMotorAsyn.c:560:50: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
         (*pPvt->drvset->getDouble)(pAxis->axis, command, value);
../drvMotorAsyn.c:543:15: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
         case -1:
../drvMotorAsyn.c:625:59: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
        status = (*pPvt->drvset->setInteger)(pAxis->axis, command, value);
../drvMotorAsyn.c:603:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
        case -1:
../drvMotorAsyn.c:665:54: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
            (*pPvt->drvset->getInteger)(pAxis->axis, command, (epicsInt32*)&temp);
../drvMotorAsyn.c:668:63: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
            status = (*pPvt->drvset->setInteger)(pAxis->axis, command, temp);
../drvMotorAsyn.c:659:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
        case -1:
../drvMotorAsyn.c:748:58: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
        status = (*pPvt->drvset->setDouble)(pAxis->axis, command, value);
../drvMotorAsyn.c:705:14: warning: case value not in enumerated type 'motorCommand' [-Wswitch]
        case -1:
../drvMotorAsyn.c:781:49: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
        (*pPvt->drvset->getDouble)(pAxis->axis, motorPosition,
../drvMotorAsyn.c:783:49: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
        (*pPvt->drvset->getDouble)(pAxis->axis, motorEncoderPosition,
../drvMotorAsyn.c:785:49: warning: implicit conversion from enumeration type 'motorCommand' to different enumeration type 'motorAxisParam_t' [-Wenum-conversion]
        (*pPvt->drvset->getDouble)(pAxis->axis, motorVelocity,
16 warnings generated.
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMotorAsyn.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../paramLib.c
../paramLib.c:110:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
    if (index >= 0 && index < params->nvals)
../paramLib.c:139:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
    if (index >=0 && index < params->nvals)
../paramLib.c:168:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
../paramLib.c:197:15: warning: comparison of unsigned expression >= 0 is always true [-Wtautological-compare]
4 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../asynMotorController.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../asynMotorAxis.cpp
/usr/bin/ar -rc   libmotor.a        motorRecord.o motordevCom.o motordrvCom.o motorUtil.o motorUtilAux.o drvMotorAsyn.o devMotorAsyn.o paramLib.o asynMotorController.o asynMotorAxis.o
/usr/bin/ranlib libmotor.a
/usr/bin/clang++ -o libmotor.so -shared -fPIC -Wl,-soname,libmotor.so -Wl,-hlibmotor.so -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               motorRecord.o motordevCom.o motordrvCom.o motorUtil.o motorUtilAux.o drvMotorAsyn.o devMotorAsyn.o paramLib.o asynMotorController.o asynMotorAxis.o    -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libmotor.so
mkdir ../../../lib
mkdir ../../../lib/linux-x86_64-debug
Installing library ../../../lib/linux-x86_64-debug/libmotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSrc'
make -C ./DeltaTauSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devDeltaTau.dbd
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/DeltaTauSrc'
make -C ./OmsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devOms.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devOmsPC68.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvOmsPC68.cc
../drvOmsPC68.cc:111:28: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *oms_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvOmsPC68.cc:111:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:38: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:43: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:48: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:53: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:58: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:111:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOmsPC68.cc:691:9: warning: add explicit braces to avoid dangling else [-Wdangling-else]
        else
9 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devOms.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvOms.cc
../drvOms.cc:156:28: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:38: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:43: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:48: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:53: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:58: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:156:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms.cc:996:19: warning: variable 'status' is uninitialized when used here [-Wuninitialized]
        errPrintf(status, __FILE__, __LINE__, "Can't disconnect vector %d\n",
../drvOms.cc:980:16: note: initialize the variable 'status' to silence this warning
    long status;
                = 0
../drvOms.cc:1157:54: warning: variable 'localaddr' is uninitialized when used here [-Wuninitialized]
            Debug(9, "motor_init: localaddr = %p\n", localaddr);
../drvOms.cc:1096:29: note: initialize the variable 'localaddr' to silence this warning
    volatile void *localaddr;
                             = NULL
../drvOms.cc:827:13: warning: unused function 'motorIsr' [-Wunused-function]
static void motorIsr(int card)
../drvOms.cc:975:13: warning: unused function 'motorIsrDisable' [-Wunused-function]
static void motorIsrDisable(int card)
12 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devOms58.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvOms58.cc
../drvOms58.cc:183:30: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *oms58_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvOms58.cc:183:35: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:45: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:50: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:55: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:60: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:183:65: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvOms58.cc:1166:54: warning: variable 'localaddr' is uninitialized when used here [-Wuninitialized]
../drvOms58.cc:1108:29: note: initialize the variable 'localaddr' to silence this warning
                             = NULL
../drvOms58.cc:1152:27: warning: variable 'status' is uninitialized when used here [-Wuninitialized]
        if (PROBE_SUCCESS(status))
../drvOms58.cc:143:33: note: expanded from macro 'PROBE_SUCCESS'
#define PROBE_SUCCESS(STATUS) ((STATUS)==S_dev_addressOverlap)
../drvOms58.cc:1103:16: note: initialize the variable 'status' to silence this warning
    long status;
                = 0
../drvOms58.cc:983:13: warning: unused function 'motorIsr' [-Wunused-function]
11 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMAXv.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMAXv.cc
../drvMAXv.cc:170:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *MAXv_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvMAXv.cc:170:34: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:44: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:49: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:54: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:59: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:170:64: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMAXv.cc:917:30: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
                MAXv_addrs = (char *) addrs;
../drvMAXv.cc:930:30: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
../drvMAXv.cc:943:30: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
../drvMAXv.cc:1040:13: warning: unused function 'motorIsr' [-Wunused-function]
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devOmsCom.cc
/usr/bin/ar -rc   liboms.a         devOmsPC68.o drvOmsPC68.o devOms.o drvOms.o devOms58.o drvOms58.o devMAXv.o drvMAXv.o devOmsCom.o
/usr/bin/ranlib liboms.a
/usr/bin/clang++ -o liboms.so -shared -fPIC -Wl,-soname,liboms.so -Wl,-hliboms.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devOmsPC68.o drvOmsPC68.o devOms.o drvOms.o devOms58.o drvOms58.o devMAXv.o drvMAXv.o devOmsCom.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/liboms.so
Installing library ../../../lib/linux-x86_64-debug/liboms.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsSrc'
make -C ./SoftMotorSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSoftMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devSoft.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devSoftAux.cc
/usr/bin/ar -rc   libsoftMotor.a         devSoft.o devSoftAux.o
/usr/bin/ranlib libsoftMotor.a
/usr/bin/clang++ -o libsoftMotor.so -shared -fPIC -Wl,-soname,libsoftMotor.so -Wl,-hlibsoftMotor.so -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devSoft.o devSoftAux.o   -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libsoftMotor.so
Installing library ../../../lib/linux-x86_64-debug/libsoftMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SoftMotorSrc'
make -C ./OmsAsynSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/omsAsynSupport.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../omsBaseAxis.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../omsBaseController.cpp
../omsBaseController.cpp:231:24: warning: unused variable 'functionName' [-Wunused-variable]
    static const char *functionName = "readInt32";
1 warning generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../omsMAXnet.cpp
In file included from ../omsMAXnet.cpp:19:
../omsMAXnet.h:38:11: warning: private field 'serialPortName' is not used [-Wunused-private-field]
    char* serialPortName;
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../omsMAXv.cpp
../omsMAXv.cpp:98:17: warning: comparison of unsigned expression < 0 is always false [-Wtautological-compare]
    if (vmeAddr < 0) {
../omsMAXv.cpp:172:21: warning: cast to 'void *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
        probeAddr = (void*) vmeAddr;
../omsMAXv.cpp:362:24: warning: unused variable 'functionName' [-Wunused-variable]
    static const char* functionName = "sendReceive";
../omsMAXv.cpp:501:28: warning: cast to 'char *' from smaller integer type 'unsigned int' [-Wint-to-pointer-cast]
    omsMAXv::baseAddress = (char *) addrs;
In file included from ../omsMAXv.cpp:24:
../omsMAXv.h:173:10: warning: private field 'readBuffer' is not used [-Wunused-private-field]
    char readBuffer[BUFFER_SIZE];
5 warnings generated.
/usr/bin/ar -rc   libomsAsyn.a         omsBaseAxis.o omsBaseController.o omsMAXnet.o omsMAXv.o
/usr/bin/ranlib libomsAsyn.a
/usr/bin/clang++ -o libomsAsyn.so -shared -fPIC -Wl,-soname,libomsAsyn.so -Wl,-hlibomsAsyn.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                omsBaseAxis.o omsBaseController.o omsMAXnet.o omsMAXv.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libomsAsyn.so
Installing library ../../../lib/linux-x86_64-debug/libomsAsyn.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OmsAsynSrc'
make -C ./MotorSimSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc/O.linux-x86_64-debug'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeIncludeDbd.pl base.dbd asyn.dbd motorSupport.dbd motorSimSupport.dbd motorSimInclude.dbd
echo "../O.Common/motorSimInclude.dbd : ../Makefile" >> motorSim.dbd.d
Expanding dbd
Installing dbd file ../../../dbd/motorSimSupport.dbd
Installing created dbd file ../../../dbd/motorSim.dbd
Installing db file ../../../db/motorSimTest.db
mkdir ../../../db
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../route.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMotorSim.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMotorSim.c
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motorSimDriver.cpp
In file included from ../motorSimDriver.cpp:25:
../motorSimDriver.h:51:18: warning: private field 'tLast_' is not used [-Wunused-private-field]
  epicsTimeStamp tLast_;
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motorSimRegister.cc
/usr/bin/ar -rc   libmotorSimSupport.a        route.o devMotorSim.o drvMotorSim.o motorSimDriver.o motorSimRegister.o
/usr/bin/ranlib libmotorSimSupport.a
/usr/bin/clang++ -o libmotorSimSupport.so -shared -fPIC -Wl,-soname,libmotorSimSupport.so -Wl,-hlibmotorSimSupport.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               route.o devMotorSim.o drvMotorSim.o motorSimDriver.o motorSimRegister.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libmotorSimSupport.so
Installing library ../../../lib/linux-x86_64-debug/libmotorSimSupport.a
perl /usr/lib/epics/bin/linux-x86_64-debug/registerRecordDeviceDriver.pl ../O.Common/motorSim.dbd motorSim_registerRecordDeviceDriver /home/marko/work/stripperFoilPlatter/motorTest/motorR6-8 > motorSim.tmp
mv motorSim.tmp motorSim_registerRecordDeviceDriver.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       motorSim_registerRecordDeviceDriver.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../motorSimMain.cpp
/usr/bin/clang++ -o motorSim  -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               motorSim_registerRecordDeviceDriver.o motorSimMain.o    -lmotorSimSupport -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing created file ../../../bin/linux-x86_64-debug/motorSim
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64-debug
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MotorSimSrc'
make -C ./NewportSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devNewport.dbd
Installing generic include file ../../../include/XPS_C8_drivers.h
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../NewportRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMM3000.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMM3000.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMM4000.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMM4000.cc
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMM4000Asyn.c
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPM500.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPM500.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devESP300.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvESP300.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../SMC100Driver.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../AG_UC.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../AG_CONEX.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../asynOctetSocket.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPS_C8_drivers.cpp
../XPS_C8_drivers.cpp:4605:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
                if (pt != NULL) sscanf (pt, "%d", &boolScanTmp);
../XPS_C8_drivers.cpp:4606:30: note: uninitialized use occurs here
                *ClosedLoopStatus = (bool) boolScanTmp;
../XPS_C8_drivers.cpp:4605:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4584:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../XPS_C8_drivers.cpp:4739:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:4740:30: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:4739:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4718:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../XPS_C8_drivers.cpp:4877:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:4878:30: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:4877:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4856:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../XPS_C8_drivers.cpp:5001:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:5002:30: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:5001:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:4980:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../XPS_C8_drivers.cpp:6153:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:6154:25: note: uninitialized use occurs here
                *EnableState = (bool) boolScanTmp;
../XPS_C8_drivers.cpp:6153:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:6126:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../XPS_C8_drivers.cpp:6245:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:6246:25: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:6245:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:6215:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../XPS_C8_drivers.cpp:6839:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../XPS_C8_drivers.cpp:6840:25: note: uninitialized use occurs here
../XPS_C8_drivers.cpp:6839:3: note: remove the 'if' if its condition is always true
../XPS_C8_drivers.cpp:6809:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
7 warnings generated.
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvXPSAsynAux.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../xps_ftp.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvXPSAsyn.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSAsynInterpose.c
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSController.cpp
In file included from ../XPSController.cpp:93:
../XPSController.h:44:14: warning: 'XPSController::initializeProfile' hides overloaded virtual function [-Woverloaded-virtual]
  asynStatus initializeProfile(size_t maxPoints, const char* ftpUsername, const char* ftpPassword);
../../../include/asynMotorController.h:171:22: note: hidden overloaded virtual function 'asynMotorController::initializeProfile' declared here
  virtual asynStatus initializeProfile(size_t maxPoints);
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSAxis.cpp
In file included from ../XPSAxis.cpp:97:
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../hxp_drivers.cpp
../hxp_drivers.cpp:55:4: warning: expression result unused [-Wunused-value]
                        *pt++;
../hxp_drivers.cpp:3644:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:3645:30: note: uninitialized use occurs here
../hxp_drivers.cpp:3644:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:3623:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../hxp_drivers.cpp:3778:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:3779:30: note: uninitialized use occurs here
../hxp_drivers.cpp:3778:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:3757:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../hxp_drivers.cpp:3916:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:3917:30: note: uninitialized use occurs here
../hxp_drivers.cpp:3916:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:3895:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
../hxp_drivers.cpp:4040:7: warning: variable 'boolScanTmp' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
../hxp_drivers.cpp:4041:30: note: uninitialized use occurs here
../hxp_drivers.cpp:4040:3: note: remove the 'if' if its condition is always true
../hxp_drivers.cpp:4019:17: note: initialize the variable 'boolScanTmp' to silence this warning
        int boolScanTmp;
                        = 0
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../HXPDriver.cpp
In file included from ../HXPDriver.cpp:21:
../HXPDriver.h:79:10: warning: private field 'mres_' is not used [-Wunused-private-field]
  double mres_;
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSGathering.c
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSGatheringRegister.c
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../tclCall.cc
/usr/bin/ar -rc   libNewport.a        NewportRegister.o devMM3000.o drvMM3000.o devMM4000.o drvMM4000.o drvMM4000Asyn.o devPM500.o drvPM500.o devESP300.o drvESP300.o SMC100Driver.o AG_UC.o AG_CONEX.o asynOctetSocket.o XPS_C8_drivers.o drvXPSAsynAux.o xps_ftp.o drvXPSAsyn.o XPSAsynInterpose.o XPSController.o XPSAxis.o hxp_drivers.o HXPDriver.o XPSGathering.o XPSGatheringRegister.o tclCall.o
/usr/bin/ranlib libNewport.a
/usr/bin/clang++ -o libNewport.so -shared -fPIC -Wl,-soname,libNewport.so -Wl,-hlibNewport.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               NewportRegister.o devMM3000.o drvMM3000.o devMM4000.o drvMM4000.o drvMM4000Asyn.o devPM500.o drvPM500.o devESP300.o drvESP300.o SMC100Driver.o AG_UC.o AG_CONEX.o asynOctetSocket.o XPS_C8_drivers.o drvXPSAsynAux.o xps_ftp.o drvXPSAsyn.o XPSAsynInterpose.o XPSController.o XPSAxis.o hxp_drivers.o HXPDriver.o XPSGathering.o XPSGatheringRegister.o tclCall.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libNewport.so
Installing library ../../../lib/linux-x86_64-debug/libNewport.a
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSGatheringMain.c
/usr/bin/clang++ -o XPSGatheringMain  -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               XPSGatheringMain.o    -lNewport -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../XPSGathering2.c
/usr/bin/clang++ -o XPSGathering2  -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               XPSGathering2.o    -lNewport -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing created file ../../../bin/linux-x86_64-debug/XPSGatheringMain
Installing created file ../../../bin/linux-x86_64-debug/XPSGathering2
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewportSrc'
make -C ./ImsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devImsMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ImsRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devIM483SM.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvIM483SM.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devIM483PL.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvIM483PL.cc
../drvIM483PL.cc:95:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *IM483PL_axis[] = {"A", "B", "C", "D", "E", "F", "G", "H"};
../drvIM483PL.cc:95:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:57: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:62: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvIM483PL.cc:95:67: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
8 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMDrive.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMDrive.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ImsMDrivePlusMotorController.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ImsMDrivePlusMotorAxis.cpp
../ImsMDrivePlusMotorAxis.cpp:307:13: warning: using the result of an assignment as a condition without parentheses [-Wparentheses]
        if (status = setAxisMoveParameters(minVelocity, maxVelocity, acceleration)) goto bail;
../ImsMDrivePlusMotorAxis.cpp:307:13: note: place parentheses around the assignment to silence this warning
../ImsMDrivePlusMotorAxis.cpp:307:13: note: use '==' to turn this assignment into an equality comparison
/usr/bin/ar -rc   libIms.a         ImsRegister.o devIM483SM.o drvIM483SM.o devIM483PL.o drvIM483PL.o devMDrive.o drvMDrive.o ImsMDrivePlusMotorController.o ImsMDrivePlusMotorAxis.o
/usr/bin/ranlib libIms.a
/usr/bin/clang++ -o libIms.so -shared -fPIC -Wl,-soname,libIms.so -Wl,-hlibIms.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                ImsRegister.o devIM483SM.o drvIM483SM.o devIM483PL.o drvIM483PL.o devMDrive.o drvMDrive.o ImsMDrivePlusMotorController.o ImsMDrivePlusMotorAxis.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libIms.so
Installing library ../../../lib/linux-x86_64-debug/libIms.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ImsSrc'
make -C ./AcsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devAcsMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../AcsRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMCB4B.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMCB4B.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../MCB4BDriver.cpp
/usr/bin/ar -rc   libAcs.a         AcsRegister.o devMCB4B.o drvMCB4B.o MCB4BDriver.o
/usr/bin/ranlib libAcs.a
/usr/bin/clang++ -o libAcs.so -shared -fPIC -Wl,-soname,libAcs.so -Wl,-hlibAcs.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                AcsRegister.o devMCB4B.o drvMCB4B.o MCB4BDriver.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libAcs.so
Installing library ../../../lib/linux-x86_64-debug/libAcs.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsSrc'
make -C ./MclennanSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../../.. T_A=linux-x86_64-debug install
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devMclennanMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../MclennanRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPM304.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPM304.cc
/usr/bin/ar -rc   libMclennan.a         MclennanRegister.o devPM304.o drvPM304.o
/usr/bin/ranlib libMclennan.a
/usr/bin/clang++ -o libMclennan.so -shared -fPIC -Wl,-soname,libMclennan.so -Wl,-hlibMclennan.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                MclennanRegister.o devPM304.o drvPM304.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libMclennan.so
Installing library ../../../lib/linux-x86_64-debug/libMclennan.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MclennanSrc'
make -C ./PiSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devPIMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIC844.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIC844.cc
../drvPIC844.cc:90:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIC844_axis[4] = {"1", "2", "3", "4"};
../drvPIC844.cc:90:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC844.cc:90:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC844.cc:90:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PiRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIC630.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIC630.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIC630Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIC848.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIC848.cc
../drvPIC848.cc:80:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIC848_axis[4] = {"A", "B", "C", "D"};
../drvPIC848.cc:80:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC848.cc:80:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC848.cc:80:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
4 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIC848Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIC662.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIC662.cc
../drvPIC662.cc:82:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIC662_axis[4] = {"1", "2", "3", "4"};
../drvPIC662.cc:82:37: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC662.cc:82:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIC662.cc:82:47: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIC662Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIC862.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIC862.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIC862Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIC663.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIC663.cc
../drvPIC663.cc:200:55: warning: unused variable 'LSactiveH' [-Wunused-variable]
    bool plusdir, ls_active = false, plusLS, minusLS, LSactiveH;
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIC663Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIE710.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIE710.cc
../drvPIE710.cc:78:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIE710_axis[] = {"1", "2", "3", "4", "5", "6"};
../drvPIE710.cc:78:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:46: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:51: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE710.cc:78:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
6 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIE710Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIE516.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIE516.cc
../drvPIE516.cc:86:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIE516_axis[] = {"A", "B", "C"};
../drvPIE516.cc:86:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE516.cc:86:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
3 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIE516Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIE816.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIE816.cc
../drvPIE816.cc:91:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIE816_axis[] = {"A", "B", "C", "D", "E", "F", "G", "H", "I", "J",
../drvPIE816.cc:91:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:46: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:51: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:61: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:66: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:71: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:91:76: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIE816.cc:92:32: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
                               "K","L"};
../drvPIE816.cc:92:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
                               "K","L"};
../drvPIE816.cc:235:66: warning: unused variable 'online_status' [-Wunused-variable]
    unsigned int overflow_status, ontarget_status, servo_status, online_status;
../drvPIE816.cc:580:10: warning: unused variable 'retry' [-Wunused-variable]
            int retry = 0;
14 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIE816Register.cc
/usr/bin/ar -rc   libPI.a         devPIC844.o drvPIC844.o PiRegister.o devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o devPIE816.o drvPIE816.o PIE816Register.o
/usr/bin/ranlib libPI.a
/usr/bin/clang++ -o libPI.so -shared -fPIC -Wl,-soname,libPI.so -Wl,-hlibPI.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devPIC844.o drvPIC844.o PiRegister.o devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o devPIE816.o drvPIE816.o PIE816Register.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libPI.so
Installing library ../../../lib/linux-x86_64-debug/libPI.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiSrc'
make -C ./PIGCS2Src install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/PI_GCS2Support.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIasynController.cpp
../PIasynController.cpp:63:4: warning: field 'm_pGCSController' will be initialized after field 'movesDeferred' [-Wreorder]
        , m_pGCSController( NULL )
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIasynAxis.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIGCSController.cpp
../PIGCSController.cpp:317:13: warning: unused variable 'status' [-Wunused-variable]
        asynStatus status;
../PIGCSController.cpp:318:7: warning: unused variable 'cmd' [-Wunused-variable]
        char cmd[100];
2 warnings generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIGCSMotorController.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIGCSPiezoController.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIE517Controller.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIE755Controller.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIHexapodController.cpp
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIC702Controller.cpp
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../translateerror.c
/usr/bin/ar -rc   libPI_GCS2Support.a        PIasynController.o PIasynAxis.o PIGCSController.o PIGCSMotorController.o PIGCSPiezoController.o PIE517Controller.o PIE755Controller.o PIHexapodController.o PIC702Controller.o translateerror.o
/usr/bin/ranlib libPI_GCS2Support.a
/usr/bin/clang++ -o libPI_GCS2Support.so -shared -fPIC -Wl,-soname,libPI_GCS2Support.so -Wl,-hlibPI_GCS2Support.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               PIasynController.o PIasynAxis.o PIGCSController.o PIGCSMotorController.o PIGCSPiezoController.o PIE517Controller.o PIE755Controller.o PIHexapodController.o PIC702Controller.o translateerror.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libPI_GCS2Support.so
Installing library ../../../lib/linux-x86_64-debug/libPI_GCS2Support.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PIGCS2Src'
make -C ./MicroMoSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devMicroMo.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../MicroMoRegister.cc
../MicroMoRegister.cc:54:13: warning: unused function 'configMicroMoCallFunc' [-Wunused-function]
static void configMicroMoCallFunc(const iocshArgBuf *args)
1 warning generated.
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMVP2001.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMVP2001.cc
/usr/bin/ar -rc   libMicroMo.a         MicroMoRegister.o devMVP2001.o drvMVP2001.o
/usr/bin/ranlib libMicroMo.a
/usr/bin/clang++ -o libMicroMo.so -shared -fPIC -Wl,-soname,libMicroMo.so -Wl,-hlibMicroMo.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                MicroMoRegister.o devMVP2001.o drvMVP2001.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libMicroMo.so
Installing library ../../../lib/linux-x86_64-debug/libMicroMo.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicroMoSrc'
make -C ./MicosSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devMicos.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../MicosRegister.cc
../MicosRegister.cc:54:13: warning: unused function 'configMicosCallFunc' [-Wunused-function]
static void configMicosCallFunc(const iocshArgBuf *args)
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMicos.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMicos.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../SMChydraDriver.cpp
In file included from ../SMChydraDriver.cpp:21:
../SMChydraDriver.h:38:10: warning: private field 'mres_' is not used [-Wunused-private-field]
  double mres_;
/usr/bin/ar -rc   libMicos.a         MicosRegister.o devMicos.o drvMicos.o SMChydraDriver.o
/usr/bin/ranlib libMicos.a
/usr/bin/clang++ -o libMicos.so -shared -fPIC -Wl,-soname,libMicos.so -Wl,-hlibMicos.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                MicosRegister.o devMicos.o drvMicos.o SMChydraDriver.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libMicos.so
Installing library ../../../lib/linux-x86_64-debug/libMicos.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/MicosSrc'
make -C ./FaulhaberSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devFaulhaberMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMCDC2805.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMCDC2805.cc
../drvMCDC2805.cc:80:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *MCDC2805_axis[] = {"0", "1", "2", "3", "4", "5", "6", "7"};
../drvMCDC2805.cc:80:38: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:43: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:48: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:53: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:58: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMCDC2805.cc:80:68: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/ar -rc   libFaulhaber.a         devMCDC2805.o drvMCDC2805.o
/usr/bin/ranlib libFaulhaber.a
/usr/bin/clang++ -o libFaulhaber.so -shared -fPIC -Wl,-soname,libFaulhaber.so -Wl,-hlibFaulhaber.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devMCDC2805.o drvMCDC2805.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libFaulhaber.so
Installing library ../../../lib/linux-x86_64-debug/libFaulhaber.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/FaulhaberSrc'
make -C ./PC6KSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devPC6K.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ParkerRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPC6K.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPC6K.cc
/usr/bin/ar -rc   libParker.a         ParkerRegister.o devPC6K.o drvPC6K.o
/usr/bin/ranlib libParker.a
/usr/bin/clang++ -o libParker.so -shared -fPIC -Wl,-soname,libParker.so -Wl,-hlibParker.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                ParkerRegister.o devPC6K.o drvPC6K.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libParker.so
Installing library ../../../lib/linux-x86_64-debug/libParker.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PC6KSrc'
make -C ./NewFocusSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devNewFocus.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../NewFocusRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPMNC87xx.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPMNC87xx.cc
/usr/bin/ar -rc   libNewFocus.a         NewFocusRegister.o devPMNC87xx.o drvPMNC87xx.o
/usr/bin/ranlib libNewFocus.a
/usr/bin/clang++ -o libNewFocus.so -shared -fPIC -Wl,-soname,libNewFocus.so -Wl,-hlibNewFocus.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                NewFocusRegister.o devPMNC87xx.o drvPMNC87xx.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libNewFocus.so
Installing library ../../../lib/linux-x86_64-debug/libNewFocus.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NewFocusSrc'
make -C ./AcsTech80Src install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSPiiPlus.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ACSTech80Register.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devSPiiPlus.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvSPiiPlus.cc
../drvSPiiPlus.cc:91:30: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *ACSPL_axis[] = {"X", "Y", "Z", "T", "A", "B", "C", "D"};
../drvSPiiPlus.cc:91:35: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:45: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:50: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:55: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:60: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:91:65: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:97:4: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
  {QSTATUS_CMND,QFAULT_CMND,QPOS_CMND,QEA_POS_CMND,QVEL_CMND,QHOME_CMND,QDONE_CMND},
../drvSPiiPlus.h:66:26: note: expanded from macro 'QSTATUS_CMND'
#define QSTATUS_CMND     "?D/MST(%d)"
../drvSPiiPlus.cc:97:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:67:26: note: expanded from macro 'QFAULT_CMND'
#define QFAULT_CMND      "?D/FAULT(%d)"
../drvSPiiPlus.cc:97:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:68:26: note: expanded from macro 'QPOS_CMND'
#define QPOS_CMND        "?APOS(%d)"
../drvSPiiPlus.cc:97:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:69:26: note: expanded from macro 'QEA_POS_CMND'
#define QEA_POS_CMND     "?FPOS(%d)"
../drvSPiiPlus.cc:97:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:71:26: note: expanded from macro 'QVEL_CMND'
#define QVEL_CMND        "?FVEL(%d)"
../drvSPiiPlus.cc:97:62: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:72:26: note: expanded from macro 'QHOME_CMND'
#define QHOME_CMND       "?opReq(%d)"
../drvSPiiPlus.cc:97:73: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:73:26: note: expanded from macro 'QDONE_CMND'
#define QDONE_CMND       "?Done(%d)"
../drvSPiiPlus.cc:98:4: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
  {QSTATUS_CMND,QFAULT_CMND,QPOS_CMND,QEA_POS_KIN_CMND,QVEL_CMND,SKIP_THIS,SKIP_THIS},
../drvSPiiPlus.cc:98:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:98:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:98:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.h:70:26: note: expanded from macro 'QEA_POS_KIN_CMND'
#define QEA_POS_KIN_CMND "?FPOS%s"    // Read reverse kinimatic position ('CONNECT' mode)
../drvSPiiPlus.cc:98:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:98:66: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:65:25: note: expanded from macro 'SKIP_THIS'
#define SKIP_THIS       "#"
../drvSPiiPlus.cc:98:76: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:4: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
  {QSTATUS_CMND,QFAULT_CMND,QPOS_CMND,QEA_POS_CMND,QVEL_CMND,SKIP_THIS,SKIP_THIS}
../drvSPiiPlus.cc:99:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:62: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSPiiPlus.cc:99:72: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
29 warnings generated.
/usr/bin/ar -rc   libacsTech80.a         ACSTech80Register.o devSPiiPlus.o drvSPiiPlus.o
/usr/bin/ranlib libacsTech80.a
/usr/bin/clang++ -o libacsTech80.so -shared -fPIC -Wl,-soname,libacsTech80.so -Wl,-hlibacsTech80.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                ACSTech80Register.o devSPiiPlus.o drvSPiiPlus.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libacsTech80.so
Installing library ../../../lib/linux-x86_64-debug/libacsTech80.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AcsTech80Src'
make -C ./OrielSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devOriel.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g -O0   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../OrielRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g -O0   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devEMC18011.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g -O0   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvEMC18011.cc
../drvEMC18011.cc:272:9: warning: variable 'brkptr' is uninitialized when used here [-Wuninitialized]
                  if (brkptr != endptr)
../drvEMC18011.cc:227:15: note: initialize the variable 'brkptr' to silence this warning
  char *brkptr, *endptr;
               = NULL
/usr/bin/ar -rc   libOriel.a         OrielRegister.o devEMC18011.o drvEMC18011.o
/usr/bin/ranlib libOriel.a
/usr/bin/clang++ -o libOriel.so -shared -fPIC -Wl,-soname,libOriel.so -Wl,-hlibOriel.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                OrielRegister.o devEMC18011.o drvEMC18011.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libOriel.so
Installing library ../../../lib/linux-x86_64-debug/libOriel.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/OrielSrc'
make -C ./ThorLabsSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devThorLabs.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g -O0   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ThorLabsRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g -O0   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devMDT695.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g -O0   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvMDT695.cc
../drvMDT695.cc:86:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *MDT694_axis[] = {"X", "Y", "Z"};
../drvMDT695.cc:86:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvMDT695.cc:86:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
/usr/bin/ar -rc   libThorLabs.a         ThorLabsRegister.o devMDT695.o drvMDT695.o
/usr/bin/ranlib libThorLabs.a
/usr/bin/clang++ -o libThorLabs.so -shared -fPIC -Wl,-soname,libThorLabs.so -Wl,-hlibThorLabs.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                ThorLabsRegister.o devMDT695.o drvMDT695.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libThorLabs.so
Installing library ../../../lib/linux-x86_64-debug/libThorLabs.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ThorLabsSrc'
make -C ./SmartMotorSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSmartMotorMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devSmartMotor.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvSmartMotor.cc
../drvSmartMotor.cc:78:35: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *SmartMotor_addr[] = {"129", "130", "131", "132", "133", "134",
../drvSmartMotor.cc:78:42: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:49: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:63: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:78:70: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
    "135", "136", "137", "138", "139", "140",
../drvSmartMotor.cc:79:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:79:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
    "141", "142", "143", "144", "145", "146",
../drvSmartMotor.cc:80:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:80:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
    "147", "148", "149", "150", "151", "152",
../drvSmartMotor.cc:81:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:81:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
    "153", "154", "155", "156", "157", "158",
../drvSmartMotor.cc:82:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:19: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:26: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:33: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:82:40: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvSmartMotor.cc:83:5: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
    "159", "160"};
../drvSmartMotor.cc:83:12: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
    "159", "160"};
../drvSmartMotor.cc:430:9: warning: variable 'addr' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
    if (cntrl->num_motors != 1) /* Test for daisy chain; echo mode. */
../drvSmartMotor.cc:440:86: note: uninitialized use occurs here
    Debug(2, "send_mess(): message = %s for card# %d, addr# %d\n", local_buff, card, addr);
../drvSmartMotor.cc:430:5: note: remove the 'if' if its condition is always true
../drvSmartMotor.cc:404:32: note: initialize the variable 'addr' to silence this warning
    int comsize, namesize, addr;
                                = 0
33 warnings generated.
/usr/bin/ar -rc   libSmartMotor.a         devSmartMotor.o drvSmartMotor.o
/usr/bin/ranlib libSmartMotor.a
/usr/bin/clang++ -o libSmartMotor.so -shared -fPIC -Wl,-soname,libSmartMotor.so -Wl,-hlibSmartMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devSmartMotor.o drvSmartMotor.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libSmartMotor.so
Installing library ../../../lib/linux-x86_64-debug/libSmartMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmartMotorSrc'
make -C ./PiJenaSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devPIJena.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devPIJEDS.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvPIJEDS.cc
../drvPIJEDS.cc:76:31: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *PIJEDS_axis[] = {"0", "1", "2", "3", "4", "5"};
../drvPIJEDS.cc:76:36: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:41: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:46: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:51: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:76:56: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:88:29: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
static char *EDS_CMNDS[] = {READ_POS, READ_STATUS, READ_SLEW};
../drvPIJEDS.cc:84:23: note: expanded from macro 'READ_POS'
#define READ_POS      "mess,#"   /* Read position command */
../drvPIJEDS.cc:88:39: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:85:23: note: expanded from macro 'READ_STATUS'
#define READ_STATUS   "stat,#"   /* Read Motor Status */
../drvPIJEDS.cc:88:52: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
../drvPIJEDS.cc:86:23: note: expanded from macro 'READ_SLEW'
#define READ_SLEW     "sr,#"     /* Read Slew Velocity V/ms */
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -DDEBUG  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../PIJEDS_Register.cc
/usr/bin/ar -rc   libPIJena.a         devPIJEDS.o drvPIJEDS.o PIJEDS_Register.o
/usr/bin/ranlib libPIJena.a
/usr/bin/clang++ -o libPIJena.so -shared -fPIC -Wl,-soname,libPIJena.so -Wl,-hlibPIJena.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devPIJEDS.o drvPIJEDS.o PIJEDS_Register.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libPIJena.so
Installing library ../../../lib/linux-x86_64-debug/libPIJena.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/PiJenaSrc'
make -C ./KohzuSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc'
perl /usr/lib/epics/bin/linux-x86_64-debug/makeMakefile.pl O.linux-x86_64-debug ../../..
mkdir O.Common
make -C O.linux-x86_64-debug -f ../Makefile TOP=../../.. T_A=linux-x86_64-debug install
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devKohzuMotor.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devSC800.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvSC800.cc
/usr/bin/ar -rc   libKohzuMotor.a         devSC800.o drvSC800.o
/usr/bin/ranlib libKohzuMotor.a
/usr/bin/clang++ -o libKohzuMotor.so -shared -fPIC -Wl,-soname,libKohzuMotor.so -Wl,-hlibKohzuMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                devSC800.o drvSC800.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libKohzuMotor.so
Installing library ../../../lib/linux-x86_64-debug/libKohzuMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/KohzuSrc'
make -C ./AttocubeSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devAttocube.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvANC150Asyn.cc
../drvANC150Asyn.cc:502:12: warning: unused function 'motorAxisProfileMove' [-Wunused-function]
static int motorAxisProfileMove(AXIS_HDL pAxis, int npoints, double positions[],
../drvANC150Asyn.cc:508:12: warning: unused function 'motorAxisTriggerProfile' [-Wunused-function]
static int motorAxisTriggerProfile(AXIS_HDL pAxis)
/usr/bin/ar -rc   libAttocube.a        drvANC150Asyn.o
/usr/bin/ranlib libAttocube.a
/usr/bin/clang++ -o libAttocube.so -shared -fPIC -Wl,-soname,libAttocube.so -Wl,-hlibAttocube.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               drvANC150Asyn.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libAttocube.so
Installing library ../../../lib/linux-x86_64-debug/libAttocube.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AttocubeSrc'
make -C ./AerotechSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devAerotech.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../AerotechRegister.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../devSoloist.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvSoloist.cc
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../drvEnsembleAsyn.cc
/usr/bin/clang -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../concatString.c
/usr/bin/ar -rc   libAerotech.a         AerotechRegister.o devSoloist.o drvSoloist.o drvEnsembleAsyn.o concatString.o
/usr/bin/ranlib libAerotech.a
/usr/bin/clang++ -o libAerotech.so -shared -fPIC -Wl,-soname,libAerotech.so -Wl,-hlibAerotech.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64                AerotechRegister.o devSoloist.o drvSoloist.o drvEnsembleAsyn.o concatString.o   -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libAerotech.so
Installing library ../../../lib/linux-x86_64-debug/libAerotech.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/AerotechSrc'
make -C ./HytecSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/HytecMotorDriver.dbd
Installing generic include file ../../../include/HytecMotorDriver.h
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../HytecMotorDriver.cpp
../HytecMotorDriver.cpp:277:17: warning: conversion from string literal to 'char *' is deprecated [-Wdeprecated-writable-strings]
        char*   hytecstr="  (HyTec Electronics Ltd., Reading, UK)";
../HytecMotorDriver.cpp:314:22: warning: format string is not a string literal (potentially insecure) [-Wformat-security]
        if (ishytec) printf(hytecstr);
../HytecMotorDriver.cpp:353:3: warning: format specifies type 'unsigned short' but the argument has type 'int' [-Wformat]
                expmodel);
../HytecMotorDriver.cpp:525:41: warning: cast to 'HytecMotorController *' from smaller integer type 'int' [-Wint-to-pointer-cast]
    HytecMotorController *pController = (HytecMotorController*) pDrv;
In file included from ../HytecMotorDriver.cpp:80:
../HytecMotorDriver.h:156:6: warning: private field 'absAskingPosition' is not used [-Wunused-private-field]
        int absAskingPosition;
../HytecMotorDriver.h:212:15: warning: private field 'pasynUser' is not used [-Wunused-private-field]
    asynUser *pasynUser;
../HytecMotorDriver.h:219:19: warning: private field 'motorThread' is not used [-Wunused-private-field]
    epicsThreadId motorThread;
7 warnings generated.
/usr/bin/ar -rc   libHytecMotor.a        HytecMotorDriver.o
/usr/bin/ranlib libHytecMotor.a
/usr/bin/clang++ -o libHytecMotor.so -shared -fPIC -Wl,-soname,libHytecMotor.so -Wl,-hlibHytecMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               HytecMotorDriver.o    -lmotor -lasyn -lIpac -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libHytecMotor.so
Installing library ../../../lib/linux-x86_64-debug/libHytecMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/HytecSrc'
make -C ./ACRSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/ACRMotorSupport.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../ACRMotorDriver.cpp
/usr/bin/ar -rc   libACRMotor.a        ACRMotorDriver.o
/usr/bin/ranlib libACRMotor.a
/usr/bin/clang++ -o libACRMotor.so -shared -fPIC -Wl,-soname,libACRMotor.so -Wl,-hlibACRMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               ACRMotorDriver.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libACRMotor.so
Installing library ../../../lib/linux-x86_64-debug/libACRMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/ACRSrc'
make -C ./SmarActMCSSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/devSmarActMCSMotor.dbd
Installing generic include file ../../../include/smarActMCSMotorDriver.h
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../smarActMCSMotorDriver.cpp
/usr/bin/ar -rc   libsmarActMCSMotor.a        smarActMCSMotorDriver.o
/usr/bin/ranlib libsmarActMCSMotor.a
/usr/bin/clang++ -o libsmarActMCSMotor.so -shared -fPIC -Wl,-soname,libsmarActMCSMotor.so -Wl,-hlibsmarActMCSMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               smarActMCSMotorDriver.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libsmarActMCSMotor.so
Installing library ../../../lib/linux-x86_64-debug/libsmarActMCSMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/SmarActMCSSrc'
make -C ./NPointSrc install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc/O.linux-x86_64-debug'
Installing dbd file ../../../dbd/NPointMotorSupport.dbd
/usr/bin/clang++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include       ../C300MotorDriver.cpp
/usr/bin/ar -rc   libNPointMotor.a        C300MotorDriver.o
/usr/bin/ranlib libNPointMotor.a
/usr/bin/clang++ -o libNPointMotor.so -shared -fPIC -Wl,-soname,libNPointMotor.so -Wl,-hlibNPointMotor.so -L/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -L/usr/lib/epics/lib/linux-x86_64-debug -Wl,-rpath,/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/lib/linux-x86_64-debug -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64-debug       -m64               C300MotorDriver.o    -lmotor -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64-debug/libNPointMotor.so
Installing library ../../../lib/linux-x86_64-debug/libNPointMotor.a
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/NPointSrc'
make -C ./Db install
make[2]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db'
mkdir O.Common
make[3]: Entering directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db/O.linux-x86_64-debug'
Installing db file ../../../db/motor.db
Installing db file ../../../db/basic_motor.db
Installing db file ../../../db/basic_asyn_motor.db
Installing db file ../../../db/IMS_extra.db
Installing db file ../../../db/XPSAuxAi.db
Installing db file ../../../db/XPSAuxAo.db
Installing db file ../../../db/XPSAuxBi.db
Installing db file ../../../db/XPSAuxBo.db
Installing db file ../../../db/XPSAuxLi.db
Installing db file ../../../db/XPSAuxLo.db
Installing db file ../../../db/XPS_extra.db
Installing db file ../../../db/HXP_extra.db
Installing db file ../../../db/HXP_coords.db
Installing db file ../../../db/ACRAux.template
Installing db file ../../../db/ACRAuxRead.template
Installing db file ../../../db/ACRAuxLi.template
Installing db file ../../../db/ACRAuxBi.template
Installing db file ../../../db/ACRAuxBo.template
Installing db file ../../../db/ACRAuxBoRBV.template
Installing db file ../../../db/TransPos.db
Installing db file ../../../db/motorUtil.db
Installing db file ../../../db/asyn_motor.db
Installing db file ../../../db/profileMoveController.template
Installing db file ../../../db/profileMoveAxis.template
Installing db file ../../../db/profileMoveControllerXPS.template
Installing db file ../../../db/profileMoveAxisXPS.template
Installing db file ../../../db/PI_Support.db
Installing db file ../../../db/PI_SupportCtrl.db
make[3]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db/O.linux-x86_64-debug'
make[2]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp/Db'
make[1]: Leaving directory `/home/marko/work/stripperFoilPlatter/motorTest/motorR6-8/motorApp'
motor record: continuously update limit switches Konrad, Martin
Re: motor record: continuously update limit switches Konrad, Martin
RE: motor record: continuously update limit switches Williams Jr., Ernest L.
Prev: Re: motorRecord simulation & STUP field Pearson, Matthew R.
Next: Re: [asyn] link already open! Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motor record: continuously update limit switches Konrad, Martin
Next: New Detectors Integrated Ahed Aladwan
