But can you compile a support module (that is using asyn and/or streamdevice) without including base.dbd in the support module's Makefile? It doesn't work for me as I had this error message during build: make[3]: Entering directory `/home/pmaslov/epics/apps/asyn/asynSup/asynSupApp/src/O.linux-x86_64' perl /opt/codac-4.0/epics/base/bin/linux-x86_64/makeIncludeDbd.pl asyn.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd asynSupInclude.dbd
echo "../O.Common/asynSupInclude.dbd : ../Makefile" >> asynSup.dbd.d Expanding dbd Error: menu not found at or before ")" in path "/opt/codac-4.0/epics/base/dbd" file "dbCommon.dbd" line 32
in path "/opt/codac-4.0/epics/modules/asyn/dbd" file "asynRecord.dbd" line 112 in path "/opt/codac-4.0/epics/modules/asyn/dbd" file "asyn.dbd" line 9 in file "../O.Common/asynSupInclude.dbd" line 1
Error: syntax error dbExpand: Input errors, no output generated -- Regards, Pavel Maslov, MS On Mon, Aug 12, 2013 at 2:55 PM, Dirk Zimoch <[email protected]> wrote:
ANJ, 20 Apr 2015 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
