1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: putNotify db links
To: EPICS <[email protected]>
Date: Thu, 15 Aug 2013 17:18:12 +0200
Hello all,
Is it possible to make a database link wait for completion?
If not, is this worth to be considered for a future EPICS version?
Example:
A seq record S triggers two records, A and B. A has an asynchronous device support (or is the beginning of a processing chain that contains an asynchronous device support).
record (seq, "S")
   field (LNK1, "A.PROC PP")
   field (LNK2, "B.PROC PP")
record (ai, "A")
   field (DTYP, "async dev sup")
   field (INP,  "...")
record (ao, "B")
   field (OMSL, "closed_loop")
   field (DOL,  "A")
   field (OUT,  "...")
When I do a caput with callback to S, the call only returns after A and B have both processed, as expected.
caput -w 10 -c S 1
However, B starts processing before A has finished. That is because A is asynchronous. Thus A has only just started processing when B is triggered. This is bad if B (or something down its processing chain) depends on A because B gets an old value.
Now it would be nice to have "put notify" links, e.g:
   field (LNK1, "A.PROC PN")
So that LNK2 is only processed when the whole LNK1 chain has finished processing.
The same syntax and mechanism may be useful for input links too in order to avoid getting old values from asynchronous device supports.
Any comments?
Does something like this already exists or is it already planned?
I think with dbPutNotify the necessary infrastructure is already there.
Dirk
Re: putNotify db links Pearson, Matthew R.
Re: putNotify db links Andrew Johnson
Prev: Watlow heater controllers James.OHea
Next: Re: putNotify db links Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
