Yasemin,
streamDevice has a ReplyTimeout which you can increase I have used this before
you could try to set that in your protocol file to 5000 and see if that helps.
If I remember right this timeout is in milliseconds.
Marty
On 08/19/13 08:30, Yasemin Barutçu wrote:
Hello,
I've been trying to connect to my machine by RS232.
I use streamDevice and Asyn Module.
When we send command "*IDN?", we expect to get "THERMO OK" from the machine.
I try the same connection on TCP/IP. I used serial to ethernet converter and
communicated with the machine. No problem occured. But when I eliminated the
converter and directly connected to the PC on RS232 port, I got the following
error when I send the command.
I guess the problem is about response time. How can I configure the response
time? Or if it is not response time problem, how can I fix it?
ERROR:
"2013/08/19 16:23:15.340949 thermoConn IDN: No reply from device within 1000 ms"
- Response Time Yasemin Barutçu
Re: Response Time Eric Norum
<2013>
2025
<2013>
2025
