Not sure... Link order?
T
----- Original Message -----
To: "Pete R Jemian" <[email protected]>, "Jan Ilavsky" <[email protected]>, "Mark Koennecke" <[email protected]>, "Timothy J. Madden" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "Arthur T.' 'Glowacki" <[email protected]>, "Nicholas Schwarz" <[email protected]>
Cc: [email protected]
Sent: Thursday, August 22, 2013 2:56:04 PM
Subject: Problems compiling Nexus library as DLL on Windows
Folks,
The EPICS areaDetector software has been successfully using the HDF5 library (1.8.7) on Windows since R1-7, about 2 years ago. However, only the statically linked version of the library was installed, which meant that areaDetector applications needed to be statically linked.
I am now writing a driver that must be dynamically linked, because it uses the Microsoft Common Library Runtime (/clr switch on linker). So I want to also install and use the dynamic version of the HDF5 library. I installed the dynamic versions of the required .lib files from HDF5-1.8.7_CMake_x64_shared.zip, from the HDF Web site.
When I try to build the ADApp\nexusSrc directory it compiles fine, but I get these errors it tries to link the DLL. Does anyone know what I am doing wrong?
J:\epics\devel\areaDetector\ADApp\nexusSrc>make
make -C O.windows-x64-dynamic -f ../Makefile TOP=../../.. T_A=windows-x64-dynamic install
make[1]: Entering directory `J:/epics/devel/areaDetector/ADApp/nexusSrc/O.windows-x64-dynamic'
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release /MACHINE:X64 /implib:NeXus.lib /out:NeXus.dll napi.obj napi5.obj napiu.obj nxdataset.obj nxio.obj nxstack.obj nxxml.obj stptok.obj ..\\..\\..\\lib\\windows-x64-dynamic\\hdf5.lib ..\\..\\..\\lib\\windows-x64-dynamic\\libszip.lib ..\\..\\..\\lib\\windows-x64-dynamic\\zlib.lib
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SHORT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT32_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT8_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT64_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_USHORT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UCHAR_g
napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_DATASET_CREATE_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SCHAR_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_FLOAT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT8_g
napi5.obj : error LNK2001: unresolved external symbol H5T_C_S1_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT16_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT16_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT32_g
napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_FILE_ACCESS_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT64_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_DOUBLE_g
NeXus.dll : fatal error LNK1120: 19 unresolved externals
make[1]: *** [NeXus.dll] Error 1120
make[1]: Leaving directory `J:/epics/devel/areaDetector/ADApp/nexusSrc/O.windows-x64-dynamic'
make: *** [install.windows-x64-dynamic] Error 2
- Problems compiling Nexus library as DLL on Windows Mark Rivers
Re: streamdevice to find the last match Benjamin Franksen
<2013>
RE: Problems compiling Nexus library as DLL on Windows Mark Rivers
<2013>
