Hey Dehong,
I was thinking along the lines of Dirk's response (leave InTerminator = CR LF). However, leaving InTerminator=; have you tried using @mismatch to instead parse the double message?
Wesley
----- Original Message -----
> From: "Dirk Zimoch" <[email protected]>
> To: "Dehong Zhang" <[email protected]>
> Cc: [email protected]
> Sent: Friday, August 23, 2013 3:55:37 AM
> Subject: Re: streamdevice to find the last match
> Hello Dehong,
> Is your record "I/O Intr"? I assume so because your STATUS protocol
> does
> not have any out command.
> In that case and if you set InTerminator = CR LF, you should
> actually
> get 2 messages and the record should be processed twice. Thus at the
> end, your record will have the correct value.
> Skipping intermediate results is tricky on the protocol level,
> because
> how should StreamDevice know that no more input is about to come?
> What
> if the gap between the messages is sometimes so big, that you
> actually
> get 2 messages?
> But In case you really always get a double message as below and want
> to
> read the second value only you can skip the first one:
> in "BOS%*d,P=%*dEOS\r\nBOS%d,P=%(otherrecord)dEOS\r\n"
> In case you may have an arbitrary number of messages connected and
> always want to skip all but the last, things become tricky. I have to
> make up a PCRE. The idea is to do a greedy search for everything up
> to
> "BOS" and then read the data. I will send you the PCRE later.
> Dirk
> On 22.08.2013 21:17, Zhang, Dehong wrote:
> > Hi Dirk and Friends,
> > (Sorry if you get this 2 times. I had a wrong address with my
> > previous send)
> > I run into 2 little problems: I wait for the hardware to send a
> > message like
> > "BOS123456,P=987654EOS\r\n".
> > Here BOS is my starting label and EOS the ending label.
> > Due to timing, which I cannot control, sometimes I would receive 2
> > messages
> > together, like:
> > "BOS123456,P=987654EOS\r\nBOS345,P=987649EOS\r\n".
> > Here the first one was sent when the state was still changing, the
> > second one
> > was sent when the state stablizes. But the time in between is so
> > short that the
> > 2 messages just come out as one. How can I skip the first match,
> > only get the
> > second/last match?
> > My protocal is like:
> > InTerminator = CR;
> > OutTerminator = CR LF;
> > ReplyTimeout = 800;
> > ReadTimeout = 100;
> > WriteTimeout = 100;
> > ExtraInput = Ignore;
> > # Reports from the controller
> > STATUS { ReplyTimeout = 50; ReadTimeout = 10; InTerminator =; in
> > "%.1/BOS([0-9,P=]*EOS)/"; }
> > I tried to use the "$" anchor, but cannot get it to work -- maybe
> > because "$" is a special
> > character in streamdevice.
> > Related to this, sometimes the time in between is not so short that
> > the 2 messages
> > do come out separately, but the time in between is short enough so
> > that my stringin
> > record misses the second message. How can I avoid this? Tune the
> > ReplyTimeout,
> > ReadTimeout and InTerminator?
> > Thank you for your advice. Best regards,
> > Dehong
- Re: streamdevice to find the last match Dirk Zimoch
Re: Asyn AutoConnect and stream device on a soft IOC Dirk Zimoch
Re: Problems compiling Nexus library as DLL on Windows Andrew Johnson
<2013>
<2013>
