1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: How to execute opi files?
To: Yasemin Barutçu <[email protected]>
Date: Tue, 27 Aug 2013 08:48:44 -0400
On Aug 27, 2013, at 1:51 AM, Yasemin Barutçu <[email protected]<mailto:[email protected]>> wrote:
I was wondering, how could I compile an OPI file which made in CSS?
You can't. Just like you can't compile *.adl, *.edl, … files of MEDM, DM2K, EDM.
 I don't want to the other users could open the CSS when they view the screen.
Is there anyway to make it executable or if there isn't, how could I give permissions to the users not to change the screen?
You can call
  css --launcher.openFile /CSS/whereever/file.opi
with the path to the *.opi file within the workspace from the command line.
This will open CSS, then open the *.opi file within CSS.
If CSS was already running, that running instance will open the *.opi file.
For file permissions, you use the normal Linux/OS X/Windows file permissions, either from the command line or within CSS via the "Properties" of the file in the Navigator.
BOY does have a no-edit option which will prevent users from opening *.opi files in the editor:
Check the preference GUI or add
org.csstudio.opibuilder/no_edit=true
to your plugin_customization.ini
-Kay
How to execute opi files? Yasemin Barutçu
Prev: TPG261 : "message too small=0" for EPICS Sanguk Won
Next: RE: TPG261 : "message too small=0" for EPICS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: How to execute opi files? Yasemin Barutçu
Next: TPG261 : "message too small=0" for EPICS Sanguk Won
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
