1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New edm widgets
Date: Tue, 27 Aug 2013 15:57:34 -0700
Hello,
I would like to create widgets that show up as Objects in the edm builder.  Instead of just Graphics/Line or Monitors/Meter (for example) there would also be an option like "Controls/NEWOBJECT," where NEWOBJECT is a widget that accepts PVs and has a list of fields that should be completed.  I realize you can do this by simply creating an embedded window called NEWOBJECT and referencing it wherever you need to, but this often seems to lead to a complicated process of locating the original file to edit it.
To my knowledge, the only way to add a new object is to actually write a new class file (like activeLineClass.cc) and header file (like activeLineClass.h) and add the edmObjects file like "activeLineClass $(EDMLIBS)/libEdmBase.so Graphics Lines."  Is this the only way to do this?  Or is there possibly a way to create an embedded window and translate this to an object.
Thank You,
James
RE: New edm widgets Sinclair, John William
Prev: motor record: soft motor & DMOV Konrad, Martin
Next: RE: streamdevice to find the last match Zhang, Dehong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motor record: soft motor & DMOV Konrad, Martin
Next: RE: New edm widgets Sinclair, John William
