1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Hardware simulator
To: Emmanuel Mayssat <[email protected]>, Pavel Maslov <[email protected]>, "Steiner, Mathias" <[email protected]>, "EPICS Tech Talk" <[email protected]>
Date: Thu, 29 Aug 2013 18:30:28 +0000
That brings an interesting question:
What are all those 'simulation' records (SIMM, SIOL) used for?
These fields are used to set up the ability to test database logic without the need to have hardware there to fail - or to test client based code such as quad centering or beam steering. You can use the link to have one record set the thing into simulation mode if all SIOL point to the same link field. There is also a SVAL field (or something close to that). This should all be explained in the record reference manual. If it isn't - someone should add it.
SIMM allows you to say that the simulation is offering up either a raw digital value that needs to go through conversion, an engineering units value - ignore the conversion part of the record - or no simulation.
Re: Hardware simulator Ralph Lange
RE: Hardware simulator Steiner, Mathias
Re: Hardware simulator Pavel Maslov
RE: Hardware simulator Emmanuel Mayssat
Prev: Re: motor record: soft motor & DMOV Konrad, Martin
Next: RE: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Hardware simulator Emmanuel Mayssat
Next: Re: Hardware simulator Ralph Lange
