1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Build problem of EPICS R3.14.12.3 for ARM processor in Linux
To: "Konrad, Martin" <[email protected]>, Jim Chen <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 29 Aug 2013 11:30:43 -0700
The compilation works until you are looking for a perl script.
Perl scripts are not compiled... the script is really missing !!!
Because the script is supposed to be in the /usr/lib/perl directory,
it is very likely to be a missing OS or perl package.
There are perl scripts in the epics distributions, but they are all located in the $EPICS_BASE.
Good luck,
PS: By the way, what are you building on? I frequently build on ARM and am planning to do more or it in the short future.
Emmanuel
> From: [email protected]
> To: [email protected]; [email protected]
> Subject: Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux
> Date: Thu, 29 Aug 2013 17:42:30 +0000
> Hi Jim,
> > Can't open perl script "/usr/lib/perl/5.14.2/ExtUtils/xsubpp": No
> > such file or directory
> I've no idea what Linux distro you're using but it looks like a problem
> caused by a missing package. For Debian this file should be in a package
> named perl-modules or libextutils-parsexs-perl. Please make sure you
> have the right package installed.
> Cheers,
> Martin
Ipac driver 2.12 now available Andrew Johnson
Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Konrad, Martin
Prev: RE: Hardware simulator Dalesio, Leo
Next: Re: motor record: soft motor & DMOV Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Konrad, Martin
Next: CSS/BOY detached view position [SEC=UNCLASSIFIED] LYNCH, Damien
