1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: autosave failure S_rpcLib_RPC_CANTSEND
Cc: [email protected]
Date: Tue, 03 Sep 2013 11:43:21 -0500
On 5/30/13 5:32 PM, J. Lewis Muir wrote:
> On 5/30/13 3:06 PM, J. Lewis Muir wrote:
>> Using nfsstat on the NFS server, I can confirm that the IOC NFS client
>> is using NFSv3.  Yes, if you'd be willing, I would love it if you could
>> send that image!  I'd like to try that to see if it helps.
> Hi, Andrew.
> Thanks for the image.  After booting with the new image, I've confirmed
> the IOC NFS client is using NFSv2 now.  And 'ls' works.  Now I'll just
> wait and see if the RPC problem comes up again.
Hi, Andrew.
Just following up to let you know that I have had no problems since
making this change.
It would be great if the root cause could be tracked down and fixed, or
if there was a way to easily configure whether to use NFSv2 or NFSv3, or
I'd even be fine with always using NFSv2, but I don't know if others
feel the same way.
Lewis
Re: autosave failure S_rpcLib_RPC_CANTSEND Ron Sluiter
Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Prev: RE: Motor field "UEIP" cause austen.rose
Next: RE: EhterCAT terminals [SEC=UNOFFICIAL] ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND Ron Sluiter
