Hi Patrick,
On 09/18/2013 07:06 PM, [email protected] wrote:
I was wondering, does the INC Makefile definition only work for files with
extension .h?
It doesn't look like it, but I think you will need to tell GNUMake how
to find the other files. The relevant rules in configure/RULES_BUILD
don't explicitly mention the .h extension:
$(INSTALL_INCLUDE)/% : $(COMMON_DIR)/%
$(ECHO) "Installing generated generic include file $@"
@$(INSTALL) -d -m $(INSTALL_PERMISSIONS) $< $(@D)
$(INSTALL_INCLUDE)/% : %
$(ECHO) "Installing generic include file $@"
$(INSTALL_INCLUDE)/os/$(OS_CLASS)/% : %
$(ECHO) "Installing os dependent include file $@"
However there is one other relevant line in that file:
vpath %.h $(USR_VPATH) $(ALL_SRC_DIRS)
That vpath tells GNUmake which directories to search for source files
with the .h extension (after which it will use the middle rule above to
install them). I suspect that all you will need to do to install .hpp
files is to add this to any Makefile that adds such filenames to INC:
vpath %.hpp $(USR_VPATH) $(ALL_SRC_DIRS)
In 3.14.12.x there is a vpath entry for .H files which we have removed
from the 3.15 branch (it caused problems on some types of file-systems)
but I think we should add a .hpp entry, since a growing number of
projects are now using this extension for C++-only headers.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Makefile definition for .hpp include files pthomas
Re: threading in asyn device support Ralph Lange
Re: threading in asyn device support Vikram Bhagat
<2013>
2025
<2013>
2025
