1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: threading in asyn device support
To: Ralph Lange <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 19 Sep 2013 08:32:55 -0700 (PDT)
Hi Ralph,
    Thanks for explanation.  One more question.
after completion of task how to delete Thread in EPICS (epicsThread), or it is not required in EPICS?
WR
-Vikram
To: EPICS Tech-Talk <[email protected]>
Sent: Thursday, September 19, 2013 11:21 AM
On 19.09.2013 10:57, Vikram Bhagat wrote:
Hello,
    I am not clear under standing the difference between epicsThreads and pthread. In developing asyn based device support, What i should be used?
  For example i make some calculation in separate thread, which was talking long time and i want to do other work in parallel.  Should i use pthread or epicsThread?
Hi Vikram,
The epicsThread API is part of the OSI layer, which adds a common EPICS API to operating system services. (E.g., threads, timers, semaphores, ...)
This ensures portability of code across all systems and architectures supported by EPICS.
For things in the OSI layer, there is usually a POSIX implementation, which is used on POSIX compliant platforms. In many cases vxWorks, RTEMS, or Windows use a different implementation for the same feature.
So:
If you use epicsThread, your code will run on all EPICS systems.
If you use pthread, your code will only run on POSIX compliant systems.
Please use the OSI APIs whenever possible, to allow as many people as possible to use your code.
HTH,
~Ralph
Re: threading in asyn device support Ralph Lange
threading in asyn device support Vikram Bhagat
Prev: Re: Makefile definition for .hpp include files Andrew Johnson
Next: Re: threading in asyn device support Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: threading in asyn device support Ralph Lange
