Am Mittwoch, 25. September 2013, 06:50:18 schrieb Eric Norum:
> I think that it's not a bug. It's more a 'least common denominator'
> issue with the assorted platforms on which EPICS runs. My approach
> has been to add a 'pleaseTerminate' event to the device private
> structure then place a check for this event right after the 'wait for
> work' event in the worker thread. Shutdown requests first set the
> pleaseTerminate event and then the normal check-for-work event.
I am using that approach, too, at least when I (have to) use semaphores
directly. Whenever possible I use message queues nowadays, and I type
the messages using a tagged union, just as I would with an algebraic
datatype in Haskell. So I have
enum msgTag {
MSG_DO_X,
MSG_DO_Y,
/* ... more message types */
and the type of messages is
union msg {
enum msgTag tag;
/* ... extra data common to all messages */
struct
/* ... whatever extra data is needed to do x */
} do_x;
struct
/* ... whatever extra data is needed to do y */
} do_y;
/* ... etc */
I even write data constructor functions, one for each message type, e.g.
__inline__ msg_do_x(/*...data needed for a message of this type */) {
/* assign the struct members here */
so I cannot forget to initialize a member. On the receiving end I use a
switch statement. In this way I can offload routine checks to the C type
checker, which makes the program much more robust against changes such
as adding a new message type. Which brings me back to the topic at hand,
since shutdown is now just another message type:
enum msgTag {
MSG_SHUTDOWN /* normally needs no extra data */
I find it much easier to reason about my code if it is structured in
this way.
Cheers
Ben
> On Sep 25, 2013, at 6:15 AM, Dirk Zimoch <[email protected]> wrote:
> > Hi folks,
> > Today I did some tests regarding "clean" shutdown of an IOC and
> > found some unsatisfying results. There seems to be no clean way of
> > destroying events, mutexes, or message queues, because they all
> > cannot be destroyed as long as there are threads waiting on them.
> > At least that is the case on Linux.
> > Example: One thread is waiting on an event. Whenever it gets
> > signaled, it does some work on hardware.
> > At exit I have do shutdown the hardware cleanly. After this time no
> > thread must try to use it any more. Also I better don't simply kill
> > the work thread while it is accessing the hardware. (And I probably
> > do not know all the threads involved). So I prefer to terminate
> > while the thread has noting to do, i.e. while it is waiting on the
> > event.
> > I had expected that when I destroy the queue, all pending threads
> > would wake up and receive an error. This is not the case. Instead I
> > found that destroying the event failed with "Device or resource
> > busy"
> > The same is true for mutexes as I tested. Also message queues cannot
> > be released like this.
> > Is this a bug or simply "unsupported"?
> > Any idea what I can do?
> > Dirk
"Make it so they have to reboot after every typo." -- Scott Adams
signature.asc
Description: This is a digitally signed message part.
- Re: cleaning up at exit and waiting threads Dirk Zimoch
- cleaning up at exit and waiting threads Dirk Zimoch
- Re: cleaning up at exit and waiting threads Eric Norum
sequencer release 2.1.14 Benjamin Franksen
Re: Generating a loadable module for cexp (epics 3.14.12.3) Sue Witherspoon
<2013>
<2013>
