Hi Matt,
On 11/10/2013 04:46 AM, Gibbs, Matt wrote:
I have a simple test script where I create a channel, then create a
new subscription, and pass in an event callback function which just
prints the current value of the PV to the terminal. Most of the
time, this works great, but maybe 20% of the time, I get two updates,
then nothing else for the duration of the program. This is always
using the same code, with the same PV. If I run ‘camonitor’ on the
PV repeatedly, I never see the same problem.
I don’t get any exception messages, and the rest of the script
doesn’t crash or halt, so it seems like the event callback just stops
getting called.
Any ideas about what might be happening, or things I can do to
further debug this?
As Dirk said its easier for us to help if you can show us the code, but
I can suggest a couple of possibilities.
Are you configuring the CA library to use pre-emptive callbacks or not?
See http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Thread
for an explanation. If you want libca run your callbacks from its
internal threads at any time (pre-emptive enabled) you must handle any
necessary locking to protect your data structures against race
conditions. If on the other hand you disable pre-emptive callbacks you
must call ca_pend_event() regularly because libca can only call your
event callbacks while your main thread is inside that routine.
Note that the callbacks will still happen in the context of those
internal libca threads, but you don't have to worry about using mutexes
to protect your data in most cases.
There is a difference between ca_pend_io() and ca_pend_event(); the
former will only result in monitor callbacks being run while the library
is waiting for channel connections and ca_get() and ca_put() operations
to complete. If the only I/O outstanding is waiting for monitor events
to fire, ca_pend_io() will return immediately without processing them,
thus you usually need to use ca_pend_event().
If that doesn't help we'll probably need to see your code to work out
what's going on.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Subscription updates halting? Gibbs, Matt
- Subscription updates halting? Gibbs, Matt
Re: autosave failure S_rpcLib_RPC_CANTSEND Ron Sluiter
RE: autosave failure S_rpcLib_RPC_CANTSEND Mark Rivers
<2013>
Re: Subscription updates halting? Dirk Zimoch
<2013>
