1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: areaDetector for a Basler GigE camera
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 20 Nov 2013 22:30:57 +0100
Hi Mark and Tom,
I tried what you suggested and after a little bit of fiddling around it
worked. I was able to see the images with the ImageJ viewer at almost
the trigger rate of 50Hz.
What puzzled me was that although I had 16bpp imagej was only displaying
8bpp and the values were wrapped around several times. Hence I tried to
use the edl screens to switch from 16bpp to 8pp and I completely messed
up the configuration of the camera. I got a lot of uknown pixel value
errors. After checking that the ioc is working fine with another camera
I tried switching of both cameras. Luckily the wrong configured one came
back in a sane state. I have no idea what went wrong, since I tried
changing the data type, the bpp, the pixel format all without any success.
The next test was now to fire up imagej on my mac (with osx 10.9). I
installed the plugin (ImageJ64 doesn't work with the plugin) and
ImageJ32 is able to load and to connect to the camera. However, I get
only "20/11/13 22:28:29.77: UpdateImage got exception: pendIO timed out"
errors.
Besides this I'm wondering how I can now include a few other plugins
like NDStats and NDOverlay.
But anyway, thanks for the fast and well directed help.
Cheers,
Flo
Am 20.11.13 09:56, schrieb [email protected]:
> Hi Florian,
> Once you have tried Mark's suggestions below, start the camera acquiring and check ARAVISCAM1:CAM:ArrayCounter_RBV to see if any arrays are being produced by the driver. If it doesn't increase then the problem is in the driver, otherwise the problem is in the plugin chain.
> As to your startup script problems, I suspect you may still be loading the AVT_Manta_1_44_4.template file in your substitution file. Have you run the aravisGigEApp/src/makeDbAndEdl.py script to make a database and screen for your particular camera? If so, then you need to point the substitution file at the database template that this script created.
> Thanks,
> Tom Cobb
>> -----Original Message-----
>> From: Mark Rivers [mailto:[email protected]]
>> Sent: 19 November 2013 21:29
>> To: 'Florian Sorgenfrei'; [email protected]
>> Cc: Cobb, Tom (DLSLtd,RAL,TEC)
>> Subject: RE: areaDetector for a Basler GigE camera
>> Assuming the driver is actually talking to the camera and getting
>> images then there are 2 common reasons that ARAVISCAM1:ARR:ArrayData
>> would have all zeros:
>> Make sure that the driver PV ArrayCallbacks is set to Enable.
>> Make sure the NDStdArrays plugin has the EnableCallbacks PV set to Yes.
>> These and other tips are contained in the areaDetector
>> "Troubleshooting" documentation:
>> http://cars9.uchicago.edu/software/epics/areaDetectorViewers.html#Troub
>> leshooting
>> I don't know why you are getting all the errors about the unknown
>> Aravis parameters, perhaps Tom Cobb who wrote the driver can help.
>> Mark
Florian Sorgenfrei
Institute for Methods and Instrumentation for Synchrotron Radiation
Research G-ISRR
Albert-Einstein-Str. 15
D-12489 Berlin
GERMANY
Tel.: +49 30 8062 12924
Fax: +49 30 8062 14987
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: areaDetector for a Basler GigE camera Mark Rivers
RE: areaDetector for a Basler GigE camera tom.cobb
areaDetector for a Basler GigE camera Sorgenfrei, Florian
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
Prev: RE: Substitutions defaults and tricks Emmanuel Mayssat
Next: RE: areaDetector for a Basler GigE camera Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: areaDetector for a Basler GigE camera tom.cobb
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
