Hi Emmanuel,
On 11/22/2013 12:56 PM, Emmanuel Mayssat wrote:
> In 3.14.x the same code that loads DBD files into the IOC is used in the
> dbExpand program, so it does the same checking. You can give dbExpand a
> -b flag to disable the monotonicity check though. Put
> DBEXPAND += -b
> into your Makefile to add that flag to all calls to dbExpand (there is a
Not in 3.14.11...
No, it was added in 3.14.12.2, almost 2 years ago:
revno: 12295
author: [email protected]
committer: Andrew Johnson <[email protected]>
branch nick: 3.14
timestamp: Mon 2011-11-21 11:33:26 -0600
message:
dbStatic: Added -b option to dbExpand
-b turns off monotonic checking of breakpoint tables.
You may be able to apply the changes to your copy though, see
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12295
Am I missing something?
3.14.11 is over 4 years old now, maybe consider upgrading? 3.14.12.4
will be out soon.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
- RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
- Re: Why should I care about breakpoint table monotonicity? Andrew Johnson
Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
<2013>
Job openings at PSI Dirk Zimoch
<2013>
