As suggested, I have installed motif...but again on compiling it shows this error: ../alLog.c: In function ‘filePrintf’: ../alLog.c:440:7: warning: variable ‘status’ set but not used [-Wunused-but-set-variable] int status; ^ ../awAlh.c: In function ‘startDrag’: ../awAlh.c:472:5: warning: variable ‘status’ set but not used [-Wunused-but-set-variable] int status, n; ^ ../awAlh.c: In function ‘drag’: ../awAlh.c:511:5: warning: variable ‘stat’ set but not used [-Wunused-but-set-variable] int stat; ^ ../awView.c: In function ‘singleClickArrowGroupW_callback’: ../awView.c:297:21: warning: variable ‘treeWindow’ set but not used [-Wunused-but-set-variable] struct subWindow *treeWindow; ^ ../axSubW.c: In function ‘exposeResizeCallback’: ../axSubW.c:396:12: warning: variable ‘oldViewHeight’ set but not used [-Wunused-but-set-variable] Dimension oldViewHeight; ^ ../browser.c: In function ‘callBrowser’: ../browser.c:71:6: warning: variable ‘status’ set but not used [-Wunused-but-set-variable] int status; ^ ../current.c: In function ‘currentAlarmHistoryWindow’: ../current.c:53:21: warning: variable ‘title’ set but not used [-Wunused-but-set-variable] Widget popup_shell,title,button; ^ ../dialog.c: In function ‘errMsg’: ../dialog.c:277:12: warning: variable ‘len’ set but not used [-Wunused-but-set-variable] size_t len; ^ ../force.c: In function ‘alForcePVSetNotConnected’: ../force.c:985:19: warning: variable ‘pcalc’ set but not used [-Wunused-but-set-variable] FORCEPV_CALC* pcalc; ^ ../force.c: In function ‘forcePVUpdateFields’: ../force.c:1028:21: error: ‘YES’ undeclared (first use in this function) pforcePV->disabled=YES; ^ ../force.c:1028:21: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [force.o] Error 1 make: *** [install.linux-x86_64] Error 2 Thanks & Regards Swati Soni
Hi Swati, You may end up with several of these errors. Your best bet to is use yum to pick up the appropriate libraries to which you will need to link. You will need the "devel" versions so that you pick up the header files ".h". For this header file, you will need openmotif. As an example: > yum list "*motif*" will list what you have installed and what there is in the repositories to install You should see openmotif-devel.i686 which is not installed. > yum install openmotif-devel This should take care of the first header file error. Pierrick On 11/27/2013 10:50 AM, Swati Soni2 wrote: Thanks Janet.. But I was using alh_1_24 for Alarm handler for base 3.14.12.3. I had created extension directory into which I copied the content of alh_1_24 and renamed it as src as described in http://www.aps.anl.gov/epics/extensions/config/index.php When I compiled it (by make on src), it got terminated ...fatal error: Xm/Xm.h :No such File or directory Thanks & Regards Swati Soni
The optional ALARMHANDLER environment variable should specify the directory where your Alarm Handler input configuration files reside and where the Alarm Handler output log files should be written. The PATH environment variable should include the directory of the alarm handler executable. Janet From: [email protected] [[email protected]] on behalf of Swati Soni2 [[email protected]] Sent: Tuesday, November 26, 2013 6:04 AM To: [email protected] Subject: Fw: Alarm Handler Hi I am using EPICS 3.14.12.3 on fedora..I want to install Alarm handler extension. Can anyone tell me how to set environment ? I had used setenv ALARMHANDLER /<path name of alh1_3_31> Bt it throws error commnad not found....Is there any other command to get it installed?? I am following http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/AlarmHandler/alhUserGuide-1.2.33/ALHUserGuide.html Thanks & Regards Swati Soni =====-----=====-----===== Notice: The information contained in this e-mail message and/or attachments to it may contain confidential or privileged information. If you are not the intended recipient, any dissemination, use, review, distribution, printing or copying of the information contained in this e-mail message and/or attachments to it are strictly prohibited. If you have received this communication in error, please notify us by reply e-mail or telephone and immediately and permanently delete the message and any attachments. Thank you -- "Whether you think you can or think you can't, either way, you are correct" -- Henry Ford _______________________________________________________________ Pierrick Hanlet IIT/Fermilab +44-(0)1235-44-5550 (RAL) +1-630-840-5555 (FNAL) +1-312-567-5745 (IIT) +1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
ANJ, 20 Apr 2015 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
