Release alh_1_24 is a very
old version (5 Feb 2008)
of the alarm handler which will not build with
EPICS base R3.14.11 or later.
Please try
using the latest release, alh1_2_33.
Janet
As suggested, I have installed motif...but again on compiling it shows this error:
../alLog.c: In function ‘filePrintf’:
../alLog.c:440:7: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
int status;
../awAlh.c: In function ‘startDrag’:
../awAlh.c:472:5: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
int status, n;
../awAlh.c: In function ‘drag’:
../awAlh.c:511:5: warning: variable ‘stat’ set but not used [-Wunused-but-set-variable]
int stat;
../awView.c: In function ‘singleClickArrowGroupW_callback’:
../awView.c:297:21: warning: variable ‘treeWindow’ set but not used [-Wunused-but-set-variable]
struct subWindow *treeWindow;
../axSubW.c: In function ‘exposeResizeCallback’:
../axSubW.c:396:12: warning: variable ‘oldViewHeight’ set but not used [-Wunused-but-set-variable]
Dimension oldViewHeight;
../browser.c: In function ‘callBrowser’:
../browser.c:71:6: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
int status;
../current.c: In function ‘currentAlarmHistoryWindow’:
../current.c:53:21: warning: variable ‘title’ set but not used [-Wunused-but-set-variable]
Widget popup_shell,title,button;
../dialog.c: In function ‘errMsg’:
../dialog.c:277:12: warning: variable ‘len’ set but not used [-Wunused-but-set-variable]
size_t len;
../force.c: In function ‘alForcePVSetNotConnected’:
../force.c:985:19: warning: variable ‘pcalc’ set but not used [-Wunused-but-set-variable]
FORCEPV_CALC* pcalc;
../force.c: In function ‘forcePVUpdateFields’:
../force.c:1028:21: error: ‘YES’ undeclared (first use in this function)
pforcePV->disabled=YES;
../force.c:1028:21: note: each undeclared identifier is reported only once for each function it appears in
make[1]: *** [force.o] Error 1
make: *** [install.linux-x86_64] Error 2
Thanks & Regards
Swati Soni
Hi Swati,
You may end up with several of these errors. Your best bet to is use yum to pick up the
appropriate libraries to which you will need to link. You will need the "devel" versions
so that you pick up the header files ".h". For this header file, you will need openmotif.
As an example:
> yum list "*motif*"
will list what you have installed and what there is in the repositories to install
You should see openmotif-devel.i686 which is not installed.
> yum install openmotif-devel
This should take care of the first header file error.
Pierrick
On 11/27/2013 10:50 AM, Swati Soni2 wrote:
Thanks Janet..
But I was using alh_1_24 for Alarm handler for base 3.14.12.3.
I had created extension directory into which I copied the content of alh_1_24 and renamed it as src as described in
http://www.aps.anl.gov/epics/extensions/config/index.php
When I compiled it (by make on src), it got terminated ...fatal error: Xm/Xm.h :No such File or directory
Thanks & Regards
Swati Soni
The optional ALARMHANDLER environment variable should specify the directory where your Alarm Handler input configuration files reside and where the Alarm Handler output log files should be written.
The PATH environment variable should include the directory of the alarm handler executable.
Janet
on behalf of Swati Soni2 [[email protected]]
Sent: Tuesday, November 26, 2013 6:04 AM
To: [email protected]
Subject: Fw: Alarm Handler
Hi
I am using EPICS 3.14.12.3 on fedora..I want to install Alarm handler extension.
Can anyone tell me how to set environment ?
I had used setenv ALARMHANDLER /<path name of alh1_3_31>
Bt it throws error commnad not found....Is there any other command to get it installed??
I am following http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/AlarmHandler/alhUserGuide-1.2.33/ALHUserGuide.html
Thanks & Regards
Swati Soni
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
- Re: Alarm Handler Jack
- Fw: Alarm Handler Swati Soni2
Re: Fw: Alarm Handler Robert Soliday
Error with Asyn and rpcgen Lucas Jose Monteiro Carvalho
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
