1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Increasing scan rate to 10 kHz
To: <[email protected]>
Date: Thu, 28 Nov 2013 17:50:28 +0100
On Thursday, November 28, 2013 14:28:20 Benjamin Franksen wrote:
> On Tuesday, November 26, 2013 17:57:43 Andrew Johnson wrote:
> > On 11/26/2013 05:20 PM, Evgeniy wrote:
> > > I can easily set scan period to 0.01 second by adding:
> > > choice(menuScan_01_second,".01 second")
> > > in dbd file.
> > Note that if the IOC's processing of all the records that have
> > SCAN=.01 second takes longer than 0.01 second to execute, the scan
> > rate will drop to 10Hz automatically. The code in
> > base/src/db/dbScan.c enforces this (3.14.12.4 will not be as strict,
> > but does still limit the processing rate if it takes longer than the
> > scan period to process all the records on the scan list).
> I am shocked/confused.
> Does that mean SCAN field and menuScan semantics will change from
> 3.14.12.3 to 3.14.12.4? I thought it was agreed upon to only make bug
> fixes when increasing the patch level version (i.e. the 4th part of
> the version number). New features would have to be in 3.15 or
> 3.14.13.
> Could you clarify the versioning policy, please?
What I meant is the possibility to configure other scan rates by (just)
changing the menuScan definition. So the question is: is this a new
feature or this already possible in R3.14.12.x? I thought that this is a
new feature in R3.15....
Cheers
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Increasing scan rate to 10 kHz Rolf Keitel
Increasing scan rate to 10 kHz Evgeniy
Re: Increasing scan rate to 10 kHz Andrew Johnson
Re: Increasing scan rate to 10 kHz Benjamin Franksen
Prev: RE: All Pvs disconnected Mark Rivers
Next: Re: Increasing scan rate to 10 kHz Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Increasing scan rate to 10 kHz Benjamin Franksen
