1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice "No reply from device" messages
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 06 Dec 2013 13:12:14 +0100
On 06.12.2013 12:42, [email protected] wrote:
Hello John,
A database modification may be enough to achieve a quiet console:
Have all the records that read the device disabled by a single control record, using the SDIS field.
Then one single toggle removes many error messages on the console.
I paste below an example from a lakeshore controller.
Ronaldo
record(bo, "$(P):DISABLE") {                                          |
   field(DESC, "Disable comms")                                        |
   field(PINI, "YES")                                                  |
   field(VAL, "0")                                                     |
   field(OMSL, "supervisory")                                          |
   field(ZNAM, "Enabled")                                              |
   field(ONAM, "Disabled")                                             |
record(stringin, "$(P):ID") {                                         |
   field(DTYP, "stream")                                               |
   field(SDIS, "$(P):DISABLE")                                         |
   field(INP, "@lakeshore336.proto getID $(PORT) $(ADDR)")             |
   field(SCAN, "$(SCAN) second")                                       |
I have seen people use some harmless status value of the device, scan that record every 10 seconds, and use its SEVR as the disable input for all other (faster) records polling the same device.
That way, when the device goes down the sources of error messages are automatically reduced to one record every 10 seconds, connection status is checked every 10 seconds, and the full set of fast scanning records continues automatically when the device is back.
Note that the SDIS links pull records into one lock set. You might want to set those to CA to avoid that.
~Ralph
StreamDevice "No reply from device" messages John Dobbins
RE: StreamDevice "No reply from device" messages ronaldo.mercado
Prev: RE: StreamDevice "No reply from device" messages ronaldo.mercado
Next: Re: which time/timestamp format to use for an EPICS facility? Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Issues Regarding Installing MEDM on Ubuntu 12.04 X86_64 computer Alok Pathak
