1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Increasing scan rate to 10 kHz
To: <[email protected]>
Date: Wed, 18 Dec 2013 14:04:54 -0600
Hi Evgeniy,
On 12/18/2013 01:07 PM, Evgeniy wrote:
> Processing of an EPICS record takes ~2 milliseconds on my SL5.3/DELL
> 2.27 GHz. It is unbelievably slow!
How are you measuring that?  There is a problem with your measurement
methodology, as Mark Rivers has shown. How long it actually takes to
process a record is *not* the same as how often you can trigger it to
process, since the latter depends on what method you are using to
trigger its processing.  Trying to create a very fast periodic thread is
never going to be an efficient way to make a record process very quickly.
You are likely to get more help from us here on tech-talk if you can
step back and explain what you are trying to achieve, i.e. give us the
big picture problem, not your current specific detail problem, because I
think you may be heading in the wrong direction.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Increasing scan rate to 10 kHz Evgeniy
Re: Increasing scan rate to 10 kHz Andrew Johnson
Re: Increasing scan rate to 10 kHz Evgeniy
Re: Increasing scan rate to 10 kHz Eric Norum
Prev: RE: Increasing scan rate to 10 kHz Mark Rivers
Next: RE: Design strategies for CSS BOY screens John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Increasing scan rate to 10 kHz Evgeniy
Next: Re: Increasing scan rate to 10 kHz Benjamin Franksen
