1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer Installation error
To: <[email protected]>
Date: Thu, 16 Jan 2014 13:01:22 +0100
On Thursday, January 16, 2014 16:37:24 Jitendra Kodilkar wrote:
> On 16 January 2014 15:54, Ganesh Jangir <[email protected]> wrote:
> > [GMRT@01HW183138 seq]$ make -s runtests
> > snc_test.t .. Can't locate Test/More.pm in @INC (@INC contains:
> > /usr/local/lib64/perl5 /usr/local/share/perl5
> > /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl
> > /usr/lib64/perl5 /usr/share/perl5 .) at snc_test.t line 5.
> One quick response, you are facing problem due to not getting perl
> module. make -s runtests not able to find/get 'More.pm' Perl module
> which is required in seq-2.1.16/test/compiler/make_test_lib.pm (use
> Test::More;).
Correct. Runnign the tests in test/compiler requires the Perl module
Test::More. You want to use your package manager (yum) to install it. I
believe in fedora the package is named perl-Test-Simple.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Sequencer Installation error Ganesh Jangir
Re: Sequencer Installation error Jitendra Kodilkar
Prev: garbage in zero length arrays Mezger Anton Christian
Next: PV for both input AND output Matteo Pardi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer Installation error Jitendra Kodilkar
Next: EPICS 3.14.12.4 base with vxWorks-6.9 compile error for the ppc604_long target Oleg A. Makarov
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
