1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Command to print out dynamically assigned TCP port
To: <[email protected]>, Murali Shankar <[email protected]>
Date: Wed, 29 Jan 2014 16:08:25 -0600
Hi Murali,
On 01/29/2014 03:32 PM, Shankar, Murali wrote:
>    If I start up multiple IOC’s on the same linux server, the IOC’s that
> start up later use a dynamically assigned TCP port.
>>>> cas warning: Configured TCP port was unavailable.
>>>> cas warning: Using dynamically assigned TCP port 33470,
>   Just curious, is there an EPICS IOC shell command that prints
> out/displays this port?
I started to reply that you can see it in the output from 'casr 2' but
that gives the UDP port and any client-specific TCP ports, not the TCP
one that you want:
Starting iocInit
## EPICS R3.14.12.4-DEV $$Date$$
## EPICS Base built Jan  8 2014
cas warning: Using dynamically assigned TCP port 37054,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
epics> casr 2
Channel Access Server V4.13
Connected circuits:
TCP 164.54.9.24:50571(tux.aps.anl.gov): User="anj", V4.13, 1 Channels,
Priority=0
	Task Id=0x7f8cc0009830, Socket FD=7
	Secs since last send   3.37, Secs since last receive   3.37
	Unprocessed request bytes=0, Undelivered response bytes=0
	State=up
	656 bytes allocated
	anj2:exit(1rw)
UDP Server:
UDP 164.54.8.188:49991(): User="", V4.13, 0 Channels, Priority=0
	Task Id=0x7f8cc4000970, Socket FD=6
	Secs since last send   3.37, Secs since last receive   1.41
	Unprocessed request bytes=0, Undelivered response bytes=16
	State=up
	272 bytes allocated
There are currently 333208 bytes on the server's free list
6 client(s), 511 channel(s), 511 event(s) (monitors) 0 putNotify(s)
14 small buffers (16384 bytes ea), and 0 jumbo buffers (2500024 bytes ea)
The server's resource id conversion table:
Bucket entries in use = 1 bytes in use = 32832
Bucket entries/hash id - mean = 0.000244 std dev = 0.015623 max = 1
The server's array size limit is 2500024 bytes max
Channel Access Address List
164.54.11.255:5065
If you can connect to a PV on that server a CA client can see it, but
that's probably not much help to you:
tux% cainfo anj2:exit
anj2:exit
    State:            connected
    Host:             tux.aps.anl.gov:45089
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
I think the answer is that there is no such command, although IMHO this
information should be available through casr.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Command to print out dynamically assigned TCP port Shankar, Murali
Prev: Command to print out dynamically assigned TCP port Shankar, Murali
Next: Re: epicsTime::strftime Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Command to print out dynamically assigned TCP port Emmanuel Mayssat
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
