1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MSI macro setting in substitutions file
To: "Westfall, Michael D" <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 13 Feb 2014 15:07:41 -0800
> Any tips for doing something like this with the existing tool?
Not possible the case you exactly describe it.
(Although this feature has been requested for many years and I haven't tried the latest version of msi)
But...
I assume that your intent is to build a db file (i.e. use dbLoadTemplate).
In that case, they are specific shell tricks (i.e. how template and substitution files are built)
and iocsh/iocinit tricks (i.e. how the files are used to populate the EPICS database).
Can you show us your real template? and possible substitution entries?
Emmanuel
Re: MSI macro setting in substitutions file Ralph Lange
MSI macro setting in substitutions file Westfall, Michael D
Prev: RE: Query on TCP IP Emmanuel Mayssat
Next: using caLab and LabVIEW to a chunk of data in LAN ccc1989
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: MSI macro setting in substitutions file Westfall, Michael D
Next: Re: MSI macro setting in substitutions file Ralph Lange
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
