1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: MSI macro setting in substitutions file
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 14 Feb 2014 17:44:05 +0100
On 14.02.2014 00:07, Emmanuel Mayssat wrote:
I assume that your intent is to build a db file (i.e. use dbLoadTemplate).
In that case, they are specific shell tricks (i.e. how template and substitution files are built)
and iocsh/iocinit tricks (i.e. how the files are used to populate the EPICS database).
If you need to do what MSI does, but need more than just plain text replacement, you might want to have a look at pymsi [1].
Cheers,
~Ralph
[1] http://www-csr.bessy.de/control/pymsi/
MSI macro setting in substitutions file Westfall, Michael D
RE: MSI macro setting in substitutions file Emmanuel Mayssat
Prev: Re: MSI macro setting in substitutions file Ralph Lange
Next: RE: record processing time Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: MSI macro setting in substitutions file Emmanuel Mayssat
Next: Re: MSI macro setting in substitutions file Ralph Lange
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
